Re: Whats best coating to store machined parts long term?
[Re: galen]
#951980
03/16/11 01:07 PM
03/16/11 01:07 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I can tell you from experence that waterproof grease and WD-40 ARE NOT SUFFICIENT to protect an engine block long term. I use a product called Picklex-20 on sanded metal panels stored inside recoating every 6 months with excellent results.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: Mopar_Country]
#951982
03/16/11 03:44 PM
03/16/11 03:44 PM
Posts: 157 Winlock, Wa
fshd4it
Winlock, Wa
I've had good luck with CRC SP-400 (p/n 03282). Aerosol can, spray it on & it dries to a waxy coating. Couple layers and it almost becomes like rubber. I use it on the boat, protects hose fittings,hyd. valves, etc from salt water, doesn't wash away.
In order to know what you want, you'll probably have to find out what you don't want.
[Re: fshd4it]
#951983
03/16/11 09:37 PM
03/16/11 09:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Cosmoline is a great option. The military stores machined stuff using it and it works.
[Re: ef8Cuda340]
#951985
03/17/11 10:29 AM
03/17/11 10:29 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
what about axle grease on the surfaces, then a few silica gel packets on top, and wrap the whole thing up tight with the saran wrap stuff they use in shipping large items?
that was kind of my plan for my big block that just came out of the Dakota, to keep it "fresh" while I do the paint and body on my Cuda.
**Photobucket sucks**
