Lifter hole vs no hole #951792
03/16/11 03:25 AM
03/16/11 03:25 AM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
I have a set of Comp Cams lifters for a big block, I noticed in the cup where the pushrod sits there is a small hole in the bottom of the cup. The Mopar Performance lifters I have do not have this hole.
Anyone know if the Comp Cam's lifters must be used with oil passing push rods to function correctly?
Thanks,
Wolfe
Re: Lifter hole vs no hole [Re: Wolfe440] #951793
03/16/11 03:28 AM
03/16/11 03:28 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Doesn't matter.. Oil originates at the lifter & can be fed to the rockers but a solid tip pushrod can be used & will block oil flow...
Re: Lifter hole vs no hole [Re: 1_WILD_RT] #951794
03/16/11 04:45 AM
03/16/11 04:45 AM
Wolfe440 Offline OP
Wolfe440  Offline OP
Good, my plan is to use solid tip push rods with the Comp lifters, just wanted to make sure its ok. Thanks!
Re: Lifter hole vs no hole [Re: Wolfe440] #951795
03/16/11 06:01 AM
03/16/11 06:01 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have these lifters in the Charger with the MP '509 cam. GREAT oil pressure, NO valve/lifter clatter, everything is good.
Re: Lifter hole vs no hole [Re: Kern Dog] #951796
03/16/11 09:40 AM
03/16/11 09:40 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Lifters are made so that they are usable on AMC which use the oil through push rods. solid push rod effectively seal the passage.
Re: Lifter hole vs no hole [Re: MoparforLife] #951797
03/17/11 11:58 AM
03/17/11 11:58 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I had a similar concern. I am using the Comp lifters with Crane gold roller rockers and crane pushrods with the hole in them.
Looks like the push rod adjuster will now be lubricated by the hole in the rocker arm as well as the pushrods. Should I be concerned about loosing oil pressure?
Im thinking that more oil on the valve train cant be a bad thing.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
