Lifter hole vs no hole
#951792
03/16/11 03:25 AM
03/16/11 03:25 AM
Posts: 217 New Port Richey, Florida
Wolfe440
I have a set of Comp Cams lifters for a big block, I noticed in the cup where the pushrod sits there is a small hole in the bottom of the cup. The Mopar Performance lifters I have do not have this hole. Anyone know if the Comp Cam's lifters must be used with oil passing push rods to function correctly? Thanks, Wolfe
Re: Lifter hole vs no hole
[Re: Wolfe440]
#951793
03/16/11 03:28 AM
03/16/11 03:28 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Doesn't matter.. Oil originates at the lifter & can be fed to the rockers but a solid tip pushrod can be used & will block oil flow...
[Re: 1_WILD_RT]
#951794
03/16/11 04:45 AM
03/16/11 04:45 AM
Wolfe440
Good, my plan is to use solid tip push rods with the Comp lifters, just wanted to make sure its ok. Thanks!
[Re: MoparforLife]
#951797
03/17/11 11:58 AM
03/17/11 11:58 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I had a similar concern. I am using the Comp lifters with Crane gold roller rockers and crane pushrods with the hole in them. Looks like the push rod adjuster will now be lubricated by the hole in the rocker arm as well as the pushrods. Should I be concerned about loosing oil pressure? Im thinking that more oil on the valve train cant be a bad thing. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
