Re: 10' A Body drum spindles
[Re: VernMotor]
#951429
03/16/11 05:04 PM
03/16/11 05:04 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
To bad you are so far away, I have the complete 10 inch drum setup from my 71 scamp just sitting here that I would gladly give away for free.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: VernMotor]
#951431
03/16/11 05:16 PM
03/16/11 05:16 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
thank you..I just need the spindles..I order brakes for them..and found out that I have B-body spindle on the car..and the brakes will not fit !
what is the car , year ? B body spindle will not fit on a 67 -72 A body , the B body used a different upper ball joint .
[Re: JohnRR]
#951432
03/16/11 06:47 PM
03/16/11 06:47 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Well they will if you use A-Body disc brake upper control arms off a 73 or newer.
[Re: rt66jim]
#951433
03/17/11 10:49 AM
03/17/11 10:49 AM
JohnRR
U.S.S.A.
That's why I am asking , if he gets the 67-72 spindle then he is going to have to either bore out the upper balljoint hole , change the upper control arm OR I think dr. diff sells an adaptor sleeve ????
