How would you restore brake dust shields? #950769
03/14/11 07:53 PM
03/14/11 07:53 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
After you blast and straighten my disc dust shields what's the best way to make them look new? Paint? Powder coat? What color? Thanks
Still looking for LM29H1B415501, '71 Demon 340
Re: How would you restore brake dust shields? [Re: PAULS_340] #950770
03/14/11 10:36 PM
03/14/11 10:36 PM
They take a debris beating like everything else under there so yes I'd powder coat, not sure what color to dup the OE finish. You mentioned straightening them, are they not avail new or good used?
Re: How would you restore brake dust shields? [Re: PAULS_340] #950771
03/14/11 11:04 PM
03/14/11 11:04 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The OE finish appears to be galvanized...if they are steel. I have seen some factory aluminum ones...73 A bodies or thereabouts...
Re: How would you restore brake dust shields? [Re: Sixpak] #950772
03/15/11 12:43 AM
03/15/11 12:43 AM
Motown, Mi
P
P
Motown, Mi
These small bolt pattern Abody shields are not repoped yet.
Re: How would you restore brake dust shields? [Re: PAULS_340] #950773
03/15/11 01:53 AM
03/15/11 01:53 AM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
Once you get them straight, bead blast, epoxy primer, high build primer, sand, prime sand until smooth and shoot them with gloss black enamel. If they are really pitted- bead blast, skim with quality lightweight skim, sand, prime, sand till nice and smooth and shoot with gloss black
