225 problem. Need help
#950415
03/14/11 12:58 AM
03/14/11 12:58 AM
Posts: 14 N.E. Ohio
SuperD
N.E. Ohio
Ok I have been having issues with my 225.I could not keep the engine running,so I started my quest of replacing part after part to find a cure. What it does exactly is it does not like to stay running, and when put into gear it shuts off. I have replaced the carb ( new, not used), battery, starter,upper/lower manifold gaskets,spark plugs, points and condenser, the list goes on. Well after replacing the points today at .020 and it no longer fires. I turned the rotor a bit to check the gap, but nothing horribly far. Before it at least fired but needed help staying running with giving it gas.Now, it does turn over and tries to start but fails. Any ideas guys? I really really need some pointers here. Oh by the way, does anyone have a picture of a correct carb set up on a slant six? I am 19 and a novice and do not know if I have it hooked up correctly, which could be my problem too.
Re: 225 problem. Need help
[Re: SuperD]
#950416
03/14/11 01:10 AM
03/14/11 01:10 AM
Posts: 2,005 s. e. pa.
calrobb2000
s. e. pa.
hi look to see where dist rotor is pointed and pull dist and check gear on base to confirm condition . make sure advance weights are free and working properly install new o ring on dist base and install dist and set dwell without vac advancs hose connected . set timing . adjust idle speed and mixture . see if you have current to the dist when ign on . is ballest resistor good ?
[Re: SCATPK]
#950421
03/16/11 10:07 PM
03/16/11 10:07 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
First off, hit the basics. Do you have fuel flowing? Do you have spark?
You found a NEW, not reman carb for the /6? Didn't think they still made them. I have found, from past experience with /6 carbs, that at least the reman ones are junk. I had an issue with my 225 getting like 8 mpg, turned out the reman carb was jetted way rich. Fortunately, it was a Holley and I was able to buy the correct et for it.
I also helped a guy troubleshoot his /6, wouldn't start. Turned out the carbon core of his coil wire had eroded back, inside the insulation, so far that it would no longer jump the gap and fire the plug, about 1" was missing.
The best way to set points on a /6 is to pull the distributor and set it up on the bench and while you are there make sure the drive gear is there, the guy above had a plastic gear that he fractured trying to "adjust" the "points" on his 77 Ram (he had electronic ignition).
Couple of things to look at.
Also, your original problem sounds like a vacuum leak. If you want help on setting up the carb, tell us what year, make and model too.
