lug nut , wheel stud problem #950244
03/13/11 09:17 PM
03/13/11 09:17 PM
KY
b5a12bee Offline OP
b5a12bee  Offline OP
KY
Looks like the previous owner put on the wrong lugs for the studs. Now three of them are stuck on the stud and the stud will just spin.It has wheel adapters on it, small to big lug pattern.Any ideas how to get the lugs off without using a tourch? There not enough room to get a saw on it. Thanks
Re: lug nut , wheel stud problem [Re: b5a12bee] #950245
03/13/11 09:22 PM
03/13/11 09:22 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I assume youve tried an Impact right? And these are not LH thread right?
Drill them out by holding the lug steady with a socket, while drilling down the center of the socket. (Hold socket with vise grips).
Gonna take some good drill bits and lotsa patience.
Re: lug nut , wheel stud problem [Re: Pacnorthcuda] #950246
03/13/11 11:05 PM
03/13/11 11:05 PM
What Pac said & spray the bit w some liquid which'll make it drill much faster
Re: lug nut , wheel stud problem [Re: RapidRobert] #950247
03/13/11 11:32 PM
03/13/11 11:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it is on the front and has drum brakes you can remove wheel tire and drum as one piece and cut the studs off from the back of the drum.
Re: lug nut , wheel stud problem [Re: stumpy] #950248
03/13/11 11:54 PM
03/13/11 11:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
He has wheel adaptors bolted on so nothing is comming off.
Air saw it length wise and you can split it open with a chisel.
Re: lug nut , wheel stud problem [Re: NITROUSN] #950249
03/14/11 12:57 AM
03/14/11 12:57 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
Had the same situation on my sons road runner, junk Cragers with adapters and striped lug nuts.
Nothing fancy or mysterious just used the "Hot Wrench."
Maynard
Re: lug nut , wheel stud problem [Re: NITROUSN] #950250
03/14/11 01:17 PM
03/14/11 01:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If he grinds the factory studs off the back of the drum then he can work on the adapter more easily. The adapter won't stop him from removing the drum from the spindle.
Re: lug nut , wheel stud problem [Re: stumpy] #950251
03/14/11 01:56 PM
03/14/11 01:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
, if it's the rear he is SOL , but notthe front.
