Torqueflite craters at strip, what went wrong? #950149
03/13/11 08:24 PM
03/13/11 08:24 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
Took the car to a out of town car show/race at a small 1/8 mile track. 69 Sat, 528 Hemi, 727, BFG drag radials. There were a few issues with the track prep, did burnout, launched hard with good bite, but about 30 ft. out, broke the tires loose a bit but drove thru it. Lined up a while later, launched with good hookup, but about 30 ft out,trans acted like it hit neutral, no forward in any gear, but maintained reverse. I backed up all the way to my trailer and winched it on. All my years with T/F's, I never broke one before! I have a good trans shop that has always done my work and the owner was a Chrysler line mechanic for years, knows TF's. I will call him monday, but I am curious as to what actually happened? If it matters, it already has a bolt in sprag. There is also no outward damage, leaks, etc. but does whine loudly when in reverse. Any thoughts on the amount of damage I'm looking at? Thanks!
Re: Torqueflite craters at strip, what went wrong? [Re: Lee446] #950150
03/13/11 08:30 PM
03/13/11 08:30 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
SOUNDS like to me you broke the sprag. CHECK for trash in the pan.
Re: Torqueflite craters at strip, what went wrong? [Re: Lee446] #950151
03/13/11 08:54 PM
03/13/11 08:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Unless you put in an A+A or COAN super/ultimate sprag a bolt in sprag is not going to save anything other than the outer race from spinning in the case. That said did you try it in manual low , assuming you have a low band apply VB , if it doesn't moved forward but has reverse it sounds like you smoked the rear clutch .
Re: Torqueflite craters at strip, what went wrong? [Re: JohnRR] #950152
03/13/11 09:25 PM
03/13/11 09:25 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
It basically has the factory valve body reworked , but fully auto. This is a street car. Tried all forward gears, no joy. I am curious as to what caused the failure, buy I guess that will come out at the autopsy! Hopefully all is repairable.
Re: Torqueflite craters at strip, what went wrong? [Re: Lee446] #950153
03/13/11 09:41 PM
03/13/11 09:41 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Tire shake will take one out fast.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Torqueflite craters at strip, what went wrong? [Re: Lee446] #950154
03/14/11 11:54 PM
03/14/11 11:54 PM
PA.
ARMY01 Offline
ARMY01  Offline
PA.
we did this one time. the part that holds the clutches broke around the shaft and let the shaft spin free
Re: Torqueflite craters at strip, what went wrong? [Re: ARMY01] #950155
03/15/11 12:13 AM
03/15/11 12:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He wouldn't have reverse if that happened , you are saying the part around the input shaft broke ?
Lee , why did it happen , can say what parts are in the trans ???
