Torqueflite craters at strip, what went wrong?
#950149
03/13/11 08:24 PM
03/13/11 08:24 PM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
Took the car to a out of town car show/race at a small 1/8 mile track. 69 Sat, 528 Hemi, 727, BFG drag radials. There were a few issues with the track prep, did burnout, launched hard with good bite, but about 30 ft. out, broke the tires loose a bit but drove thru it. Lined up a while later, launched with good hookup, but about 30 ft out,trans acted like it hit neutral, no forward in any gear, but maintained reverse. I backed up all the way to my trailer and winched it on. All my years with T/F's, I never broke one before! I have a good trans shop that has always done my work and the owner was a Chrysler line mechanic for years, knows TF's. I will call him monday, but I am curious as to what actually happened? If it matters, it already has a bolt in sprag. There is also no outward damage, leaks, etc. but does whine loudly when in reverse. Any thoughts on the amount of damage I'm looking at? Thanks!
Re: Torqueflite craters at strip, what went wrong?
[Re: Lee446]
#950153
03/13/11 09:41 PM
03/13/11 09:41 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Tire shake will take one out fast.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: ARMY01]
#950155
03/15/11 12:13 AM
03/15/11 12:13 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
we did this one time. the part that holds the clutches broke around the shaft and let the shaft spin free
He wouldn't have reverse if that happened , you are saying the part around the input shaft broke ?
Lee , why did it happen , can say what parts are in the trans ???
