Wiped cam? #950058
03/13/11 06:18 PM
03/13/11 06:18 PM
East Tennessee
73challenger_tn Offline OP
East Tennessee
Hello, I built a new 360 last fall and it has around 500 miles on it. I have had a problem with what I thought was rocker arms backing off. I tighten this one and maybe a hundred miles later it will be loose again. I didn't do anything special when breaking it in since its a hydraulic roller cam. This rocker arm is screwed it alot more than the rest of the rockers. The 89 roller motor was a factory roller so I reused the factory lifters. The motor runs amazing between the ticking. Could the lifter just be compressing? I hope so! Could this have been my problem?Here are the specs.
RHS heads
Indy rockers 1.5
Comp big mother thumper roller
Crane retrofit pushrods
Re: Wiped cam? [Re: 73challenger_tn] #950059
03/13/11 06:31 PM
03/13/11 06:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You need to look in there , if you have a problem it's going to be very hard to diagnose over the computer .
Re: Wiped cam? [Re: 73challenger_tn] #950060
03/13/11 09:13 PM
03/13/11 09:13 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You can cut the oil filter and look for metal, they use it on aircraft filters every time the oil is changed. Tim
Re: Wiped cam? [Re: astjp2] #950061
03/13/11 10:41 PM
03/13/11 10:41 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
What oil were you using?Did it have zinc in it?Most off the shelf oil has no zinc and will wipe a cam out in a hurry.
Re: Wiped cam? [Re: wannadrag] #950062
03/14/11 09:50 AM
03/14/11 09:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He has a ROLLER cam , not an issue .
Re: Wiped cam? [Re: JohnRR] #950063
03/14/11 04:36 PM
03/14/11 04:36 PM
East Tennessee
East Tennessee
Well, I bought two new roller lifts and a oil change yesterday. A bad lifter seems to have similar symptoms.
Re: Wiped cam? [Re: 73challenger_tn] #950064
03/14/11 07:36 PM
03/14/11 07:36 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
You also could have a valve seat pounding out.
