#950058 - 03/13/11 04:18 PM Wiped cam?
73challenger_tn Offline
Loc: East Tennessee
Hello, I built a new 360 last fall and it has around 500 miles on it. I have had a problem with what I thought was rocker arms backing off. I tighten this one and maybe a hundred miles later it will be loose again. I didn't do anything special when breaking it in since its a hydraulic roller cam. This rocker arm is screwed it alot more than the rest of the rockers. The 89 roller motor was a factory roller so I reused the factory lifters. The motor runs amazing between the ticking. Could the lifter just be compressing? I hope so! Could this have been my problem?Here are the specs.
RHS heads
Indy rockers 1.5
Comp big mother thumper roller
Crane retrofit pushrods
#950059 - 03/13/11 04:31 PM Re: Wiped cam? [Re: 73challenger_tn]
JohnRR Offline
Loc: U.S.S.A.
You need to look in there , if you have a problem it's going to be very hard to diagnose over the computer .
#950060 - 03/13/11 07:13 PM Re: Wiped cam? [Re: 73challenger_tn]
astjp2 Offline
Loc: Utah and Alaska
You can cut the oil filter and look for metal, they use it on aircraft filters every time the oil is changed. Tim
#950061 - 03/13/11 08:41 PM Re: Wiped cam? [Re: astjp2]
wannadrag Offline
Loc: WI
What oil were you using?Did it have zinc in it?Most off the shelf oil has no zinc and will wipe a cam out in a hurry.
#950062 - 03/14/11 07:50 AM Re: Wiped cam? [Re: wannadrag]
JohnRR Offline
Loc: U.S.S.A.
He has a ROLLER cam , not an issue .
#950063 - 03/14/11 02:36 PM Re: Wiped cam? [Re: JohnRR]
Loc: East Tennessee
Well, I bought two new roller lifts and a oil change yesterday. A bad lifter seems to have similar symptoms.
#950064 - 03/14/11 05:36 PM Re: Wiped cam? [Re: 73challenger_tn]
drew72 Offline
Loc: S.E.Mich
You also could have a valve seat pounding out.
25,378 Registered Members
191,012 Topics
Any luck with aftermarket fuel gauges?
by hyefatman
Today at 02:25 PM
transission help, racecar to street car
by mcat4321
Today at 02:24 PM
11.50 class at Monster Mopar Norwalk
by B3422W5
Today at 01:03 PM
Diablo (Truck Pulling) Off to a good start this season*Video
by Diablo
Today at 12:50 PM
