To spool or not ? #949645
03/13/11 12:21 AM
03/13/11 12:21 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
Building a new bullet for my dart,Bought a dana with a powerlock.Should I be putting in a spool? I do have one just wondering.
Re: To spool or not ? [Re: dart443] #949646
03/13/11 12:26 AM
03/13/11 12:26 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
spool
1.39 9.85 - 137 mph
Re: To spool or not ? [Re: dart443] #949647
03/13/11 12:31 AM
03/13/11 12:31 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
When the p/lock blows up,get a spool
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: To spool or not ? [Re: Ari440] #949648
03/13/11 12:31 AM
03/13/11 12:31 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
Spool here. NO don't wait till it BLOWS. it most likley will take out more than just the diff if it goes, if your lucky it wont kill trans/drive shaft or the car if your going down track at anything over 10mph.
Re: To spool or not ? [Re: dart443] #949649
03/13/11 12:33 AM
03/13/11 12:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What do you do with the car
Re: To spool or not ? [Re: dart443] #949650
03/13/11 12:33 AM
03/13/11 12:33 AM
Is this a street car, street and strip car or a race only car? If race only use the spool If not a race car try the posi first and see if yuo like it or not If you don't like it change to the spool then, it is not real hard in the car I used a spool in my street and strip car because I didn't have a posi for the gear ratio I wanted to use, 4.10 I may end up taking that spool out now and replace it with a 4.10 posi that I have acquired since then The spool makes backing into a parking space a pain and it is hard on the axles on the street The choice is yours, good luck
Re: To spool or not ? [Re: MR_P_BODY] #949651
03/13/11 12:55 AM
03/13/11 12:55 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
race car with a ez headed 493 aprox 700hp
Re: To spool or not ? [Re: dart443] #949652
03/13/11 01:02 AM
03/13/11 01:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Spool
Re: To spool or not ? [Re: MR_P_BODY] #949653
03/13/11 01:04 AM
03/13/11 01:04 AM
hemi-itis Offline
hemi-itis  Offline
Spool
Spool it now and sell the power lock
Re: To spool or not ? [Re: dart443] #949654
03/13/11 01:14 AM
03/13/11 01:14 AM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
Thanks guys,that's what i thought.I'm a little concerned about breaking an axle with a spool.
Re: To spool or not ? [Re: hemi-itis] #949655
03/13/11 01:26 AM
03/13/11 01:26 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Spool
X2
Re: To spool or not ? [Re: dart443] #949656
03/13/11 02:05 AM
03/13/11 02:05 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'll go ahead and answer your next question right here and now.
Get good axles too.
Stock axles need not apply.
Re: To spool or not ? [Re: tubtar] #949657
03/13/11 02:24 AM
03/13/11 02:24 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Get good axles too.
Sorry for the dumb question but, can you even get a spool with stock axle spline?
I put 35 spline in mine from DR Diff and never looked back
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: To spool or not ? [Re: DemonDust] #949658
03/13/11 04:04 AM
03/13/11 04:04 AM
Get good axles too.
the 1970 and later Mopar car Dana 60 came with 35 spline axles stock
Re: To spool or not ? [Re: Cab_Burge] #949659
03/15/11 09:30 AM
03/15/11 09:30 AM
pa
572charger Offline
572charger  Offline
pa
had stock dana 60 1968 [out of my 440 4spd charger r/t] rear in my car for years we changed the gear and axles to run in the 10s ran many 9 sec and and acouple of 8 sec passes with it never hurt the posi ! i dont' know how the after market posi stack up to a factory one . the rear is in 440drivers 70 coronet , i got a moser with a spool now . only difference is i won,t push easy and it wears out tires twice as fast on the street !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: To spool or not ? [Re: 572charger] #949660
03/15/11 09:54 AM
03/15/11 09:54 AM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
sorry to high jack, but it's a similar ? my car is 685 hp, dana 60 with a detroit locker. the local rearend guru said going to a spool would improve my 60' times. any thoughts our experience with this change
Re: To spool or not ? [Re: w2stroker] #949661
03/15/11 04:51 PM
03/15/11 04:51 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Interesting question,a locker behaves like a spool,the difference being a spool weighs less.Would that make any difference in the 60ft?I'm guessing not,but would like to here from someone who made the switch.
Re: To spool or not ? [Re: w2stroker] #949662
03/15/11 05:30 PM
03/15/11 05:30 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
don't see how its gonna make a difference if the locker is working properly and the car hooks and goes straight. i have a detroit locker in my dart, there a tough unit. only thing i could see is a little bit of rotating weight savings....
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
