Re: 440 motor mounts
[Re: cornet684me]
#949398
03/12/11 08:11 PM
03/12/11 08:11 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
where do i get the poly mounts, is the difference between the torque strap and poly mounts the price?
Look up "Schumacher Creative Services" They are about @150/pair and they don;t sell them individually. You probably don't want both as you will get vibration (they are very stiff), so use a stocker on the passenger side. The torque strap is just a different way of doing the same thing--restricting excessive engine movement. Both work.
[Re: cornet684me]
#949401
03/12/11 08:15 PM
03/12/11 08:15 PM
Pacnorthcuda
i am showing the torque strap to be about 80bucks and the poly loc mounts to be 157.00, can you buy only 1 poly loc mount? there is nothing wrong with the passenger side and i have never heard about blowing out the passenger side?
I had to buy 2, still have the 2nd one laying around somewhere. He doesn't sell singles, probably because most people would only buy 1.
[Re: Pacnorthcuda]
#949406
03/13/11 08:44 AM
03/13/11 08:44 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
If you see Schumaccher at a swap meet you can buy one.Steve at Imperial Services also has the.I got the ones for my 65 B and the kids 62 300 from him.I used to tear a mount in about 2 weeks.Now the polys are 5 years old and no problem.I dont have much more vibration than the rubbers had.Rocky
Chrysler Firepower
[Re: therocks]
#949407
03/13/11 02:41 PM
03/13/11 02:41 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
I'm using Dynatech Mighty Mounts. Got them at Spring Fling several years ago. The thing I like about them unlike the Schumacker's mounts, is that they allow the motor to move around like stock rubber mounts, but have a positive lock when fully extended. They are pricey to but look and function like stockers, except for their unbreakable design function.
There are made of tough rubber like the stock mounts, but with two studs that have an angled head on the end which lock into the top plate. There are no movement-limiting, interlocking plates encased on inside the mount like Schumackers's uses.
On the Schumacker mounts once those two interlocking metal tabs are encased in their poly material, it really limits the amount of movement the mount can make.
I'm running a shaker hood and wanted more of the stock type of free play for the motor to shake.
If you need to limit the movement of your motor for hood clearance or other issues and don't want to run a solid mount, Schumacker mounts would be a good way to go.
If you don't want to spend the money to avoid having to use chain or torque straps. You can relatively easily install a chain on the back side of the driver's side motor mount to limit upward movement, while using stock mounts. It's a cheap, effective, reliable and relatively hard to see modification when done correctly.
Notice the stud is too long on this mount, and it's actually touching the block. It stopped the motor from settling down into the K-member slightly. For whatever reason, I didn't pay much attention to it at the time I installed it. I got them warrantied later on and the mounts they sent me to replace them had a shorter stud. I could have just trimmed them down a bit, but if anyone wants them, let me know???
Also, they are side specific, driver's on driver's etc.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: cornet684me]
#949410
03/20/11 12:42 AM
03/20/11 12:42 AM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
update, i forgot how much trouble it is to put motor mounts in a car, PIA, i got up at about 6:30am this morning, i got thru about 2pm, everything turned out great, i do not know if it is in my head or not, i think i can feel the solid mount alittle, however not too bad, and i love the idea of not having to replace it forever! i bought 2 motor mounts for 27.95 from summit, so now i have enough to do another car, thanks for all the input, hope this info may help somebody else
