Re: Know where I can get GOOD T/A pushrods?
[Re: autoxcuda]
#949234
03/12/11 03:41 PM
03/12/11 03:41 PM
Posts: 1,046 Colorado Springs
T/A CARe
Colorado Springs
Was the cup hitting the bottom of the rocker?
I "think" that's what was happening. With the longer than stock rods (7.5625) vs. stock (7.4375) the adjustment screw & ball had to be farther up in the rocker, allowing the pushrod cup to hit the bottom of the rocker...
I have used shorter rods (7.25) which cause a little too steep an angle as the ball enters the lifter and chews up the end. (See pic) Thoughts?
The original T/A rod is on top.
I'll look up the links above and see what they say.
[Re: T/A CARe]
#949235
03/12/11 04:38 PM
03/12/11 04:38 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
You need a length checking pushrod , with 2 threads of the adjuster showing out of the bottom of the rocker that will be the length pushrod you need , if the heads and the block have been decked a lot you would need a shorter pushrod .
[Re: JohnRR]
#949236
03/12/11 04:41 PM
03/12/11 04:41 PM
Posts: 27,548 So Cal
autoxcuda
So Cal
Like this...
