picked up a 440....cast or forged crank? #949174
03/12/11 01:03 PM
03/12/11 01:03 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
Just picked up a 440 short block. Don't have a lot in it, hoping it is a forged crank. Date code is 1970. Stock internals. Id pad has c440 on it. No balancer or waterpump. Any ideas? I don't know how to tell just by looking at it. Any help appreciated. Thanks,
Tommy
Re: picked up a 440....cast or forged crank? [Re: Tommy383] #949175
03/12/11 01:26 PM
03/12/11 01:26 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
You have to pull the oil pan to look at the parting line running longitudinally, front to back, on the crank. Wide margin is forged, narrow is cast.
No telling otherwise. Too much time has gone by since new. Forged crank was new for 440 in 73, 71 for 383. Have bought 72 and older 440's that were serviced with cast cranks.
Tear into it.
Re: picked up a 440....cast or forged crank? [Re: Tommy383] #949176
03/12/11 01:28 PM
03/12/11 01:28 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
assuming that it is the original crank, it's forged. what does the balancer look like, thick & odd shaped or standard thin damper?
Re: picked up a 440....cast or forged crank? [Re: Dean_Kuzluzski] #949177
03/12/11 01:35 PM
03/12/11 01:35 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Don't you mean Cast?
!970 should be forged but as stated above it certainly could have been changed in the last 41 years.
Even if you do have the original forged crank you still need to determine if it is internally or externally ballanced so that you can install the correct damper and flywheel or converter.
Re: picked up a 440....cast or forged crank? [Re: Tommy383] #949178
03/12/11 01:51 PM
03/12/11 01:51 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
Tommy
its a c or G if g is 71 440 if c is 67 440
is forged crank.
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: picked up a 440....cast or forged crank? [Re: Tommy383] #949179
03/12/11 01:52 PM
03/12/11 01:52 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Date code is 1970 and the pad is C440? It can't be, you have mis-read one or the other. C440 is 1967. F440 is 1970.
Either year, if it is the original crank to the block, it's forged.
To check for forged, if the crank is out of the block, tap it with a hammer to see if it rings or look for the wide (1/4"-3/8") parting line
Re: picked up a 440....cast or forged crank? [Re: B5 Bee] #949180
03/12/11 02:05 PM
03/12/11 02:05 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
my 71 440 g cast Date code is 7 23 70
Re: picked up a 440....cast or forged crank? [Re: 440beep] #949181
03/12/11 05:53 PM
03/12/11 05:53 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
i have a d383 block that was assembled 10 67 and cast 9 of 66 just for oddity...
take a pic of the crank and post it
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: picked up a 440....cast or forged crank? [Re: GomangoCuda] #949182
03/12/11 06:13 PM
03/12/11 06:13 PM
Holly/MI
Holly/MI
Whoops! Didn't slow down to proof read. But you guys knew what I meant.
Re: picked up a 440....cast or forged crank? [Re: Tommy383] #949183
03/12/11 06:18 PM
03/12/11 06:18 PM
Northwest
Four40mopar Offline
Four40mopar  Offline
Northwest
Tap it with a combo wrench, if it rings its forged, if it clunks it cast.
Re: picked up a 440....cast or forged crank? [Re: Four40mopar] #949184
03/12/11 09:56 PM
03/12/11 09:56 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
Sorry...it is g440....according to what I have been told to look for it is forged. The ridge is very large sitting next to my cast 400. .I have 40 bucks in it....so I hope I did well. Thanks all for your help.
Re: picked up a 440....cast or forged crank? [Re: Four40mopar] #949185
03/12/11 11:31 PM
03/12/11 11:31 PM
RapidRobert Online content
RapidRobert  Online Content
I like that one!
Re: picked up a 440....cast or forged crank? [Re: RapidRobert] #949186
03/12/11 11:43 PM
03/12/11 11:43 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
If it has the full depth hole for a pilot bushing it's forged. I have yet to find a BB cast crank with a pilot bushing hole that was drilled to depth. I even took a 400 out of a 75 pickup that had a 4 spd and it was a forged crank. Not saying they aren't out there, but I've looked at a lot of crankshafts and I haven't seen one yet.
Also, if you get the pan off and look the counterweights over good, the cast will look very nice and squared. The forging is rather an ugly piece. And a cast 440 crank will have 440 cast into it on one of the counterweights.
One more thing, unless it's been previously balanced or has six pack rods, it'll be internally balanced.
Re: picked up a 440....cast or forged crank? [Re: dodgeboy11] #949187
03/12/11 11:47 PM
03/12/11 11:47 PM
is that for cast cranks also?
Re: picked up a 440....cast or forged crank? [Re: RapidRobert] #949188
03/12/11 11:48 PM
03/12/11 11:48 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
No, sorry, should have clarified, that's steel crank only.
Re: picked up a 440....cast or forged crank? [Re: dodgeboy11] #949189
03/12/11 11:54 PM
03/12/11 11:54 PM
Thanks bro
