05 hemi truck has a shudder after 2nd startup??? #948506
03/11/11 01:21 PM
03/11/11 01:21 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
we have 84,000 miles on my wifes 05 hemi PU and
when she starts it up and goes to work it is fine but if she stops the truck(like for gas or shopping) and goes again after a few minutes the truck will shutter or buck for about 15 seconds. and now the check engine lite is on.
all we have done to the truck is change the oil and filter every 3,000 mi.
I am sure it will need plugs(how long do the factory plugs last?)
any Idea what might be wrong? thanks in advance. Ron...
Re: 05 hemi truck has a shudder after 2nd startup??? [Re: Mopar Ron] #948507
03/11/11 02:25 PM
03/11/11 02:25 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
These trucks are notorious for bad plug wires. But be prepared, you have 16 of them bad boyz. And 16 plugs of course.
Re: 05 hemi truck has a shudder after 2nd startup??? [Re: drew72] #948508
03/11/11 10:53 PM
03/11/11 10:53 PM
we plan to change the plugs and wires
anyone else??? any ideas what else to look at? Ron...
Re: 05 hemi truck has a shudder after 2nd startup??? [Re: Mopar Ron] #948509
03/12/11 12:01 AM
03/12/11 12:01 AM
IN
ahy Offline
ahy  Offline
IN
Plugs are standard copper type with recommended replacement at 32k. They will last longer than that but at 60+k its time for plugs. My '06 is coil on plug so wires aren't an issue. Not sure on the '05.
I'd replace the plugs and get the code read - Autozone or others can do it for free. If the code is "misfire" or something like that its probably the plugs.
Re: 05 hemi truck has a shudder after 2nd startup??? [Re: ahy] #948510
03/12/11 12:31 AM
03/12/11 12:31 AM
Pittsburgh, PA
bobdog106 Offline
bobdog106  Offline
Pittsburgh, PA
If the truck shuts down also for no reason, change the Cam and Crank sensor. They are cheaper at the dealer, like 19 bucks instead of 80. It fixed my truck that would shudder and shut down.
Re: 05 hemi truck has a shudder after 2nd startup??? [Re: Mopar Ron] #948511
03/12/11 12:45 AM
03/12/11 12:45 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Thats your clue....What is the code?
Re: 05 hemi truck has a shudder after 2nd startup??? [Re: NITROUSN] #948512
03/12/11 01:38 AM
03/12/11 01:38 AM
my sons friend has a analyzer and is going to check the codes for me monday.
if the plugs should have been changed at 32,000
I guess that at 84,000 that will probably be the problem
Re: 05 hemi truck has a shudder after 2nd startup??? [Re: ahy] #948513
03/12/11 07:47 AM
03/12/11 07:47 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
Dang, Sounds like I'm due to change my plugs in the 03, I'm up to 104,000 miles....
Re: 05 hemi truck has a shudder after 2nd startup??? [Re: POZEST] #948514
03/12/11 08:23 AM
03/12/11 08:23 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The high level of reliability of newer cars has many people forgetting to properly maintain them. Yes, the plugs in the 5.7 HEMI motors may last longer than the recommended interval, but changing them is cheap insurance. Pulling plugs from aluminum heads after THREE TIMES THE FACTORY RECOMMENDED MILEAGE isn't smart. The chance of tearing the aluminum threads increases dramatically.
I have a 2007 Ram that developed a shudder that turned out to be a failing lifter to a cylinder controlled my the MDS system. Stuff like that doesnt show up on any code reader. My truck required removal of one cylinder head, removal of one piston and rod, honing of the cylinder and replacement of the dead lifter. That came to $3800. There was no culpability on my part. It was simply a defective part that gave out. The NON Chrysler warranty company tried to deny the claim because I didnt keep accurate oil change records. This was despite the fact that the problem was totally unrelated to the oil.
Re: 05 hemi truck has a shudder after 2nd startup??? [Re: Mopar Ron] #948515
03/12/11 10:00 AM
03/12/11 10:00 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
No scanner needed, just turn the key from off to run three times, leave it in run the third time and the code will show up on the cluster (where the odometer is). You'll see some dotted lines, then the code(s), and then "done".
There are only 8 plug wires. The remaining 8 plugs have the coil sitting right on top of them.
Some of them will miss at 60k, others will go past 100k and run exactly the same, but they're supposed to be changed every 32k as said above.
Good luck with it
Re: 05 hemi truck has a shudder "EDIT" [Re: ZIPPY] #948516
03/12/11 07:54 PM
03/12/11 07:54 PM
just checked the truck and the dash has 2 codes show up
P 0315 and
P 0300
can anyone tell me what these are Thanks, Ron...
EDIT:
I found this on line
P 0315= NO CRANK SENSOR LEARNED
P 0300= MULTIPLE CYLINDER MISFIRE
so I guess I got my moneys worth out of those plugs
I'll do better maintenance on it from now on
