4.56 gear rpm with 3.31 stroke small block in 1/4 #948486
03/11/11 12:53 PM
03/11/11 12:53 PM
Eastern Ohio
mopowergtx Offline OP
Eastern Ohio
What would a 3.31 stroke 450hp SB cross the line with in the 1/4 mile with 29" tall slicks?
Re: 4.56 gear rpm with 3.31 stroke small block in 1/4 [Re: mopowergtx] #948487
03/11/11 12:59 PM
03/11/11 12:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
what weight
Re: 4.56 gear rpm with 3.31 stroke small block in 1/4 [Re: MR_P_BODY] #948488
03/11/11 01:09 PM
03/11/11 01:09 PM
Eastern Ohio
Eastern Ohio
About 3500 with driver.
Re: 4.56 gear rpm with 3.31 stroke small block in 1/4 [Re: mopowergtx] #948489
03/11/11 01:36 PM
03/11/11 01:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can use this site and plug in your numbers
http://www.wallaceracing.com/Calculators.htm
Re: 4.56 gear rpm with 3.31 stroke small block in 1/4 [Re: MR_P_BODY] #948490
03/11/11 01:39 PM
03/11/11 01:39 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
6 grand.
Re: 4.56 gear rpm with 3.31 stroke small block in 1/4 [Re: mopowergtx] #948491
03/11/11 02:22 PM
03/11/11 02:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
It depnds on how well it leaves the starting line(spins or dead hooks) which type of trans and if it is a automatic how good the converter is and where you shift the motor at in each gear If you use one of the on line calculators plug in 6 to 10 % converter slippaged to get a real world RPM
Re: 4.56 gear rpm with 3.31 stroke small block in 1/4 [Re: mopowergtx] #948492
03/11/11 05:13 PM
03/11/11 05:13 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I will give a guestimate of 6200
