71 challenger side pic #948292
03/11/11 10:02 AM
03/11/11 10:02 AM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
I need a pic of the side of a 71 challenger showing the front fender with the challenger script. any one have an origanal car with those emblems? My cars at the body shop and we are at the point where the fenders are being done and as far as I can tell my fenders are from a 70 with the emblems are ubove the body line. I beleave they should be below the line. I need to figure out their placement. Thanks
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: 71 challenger side pic [Re: yella71] #948293
03/11/11 10:32 AM
03/11/11 10:32 AM
GA
Boosted Offline
Boosted  Offline
GA
I found this one online.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: 71 challenger side pic [Re: Boosted] #948294
03/11/11 10:45 AM
03/11/11 10:45 AM
GA
Boosted Offline
Boosted  Offline
GA
Then I found this one and it is in a diffrent location also..
2011 RAM3500
Re: 71 challenger side pic [Re: Boosted] #948295
03/12/11 03:02 PM
03/12/11 03:02 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
That second picture is not correct for a '71, '71's were below the contour line.
Here is a picture of the side of one of my cars.
Re: 71 challenger side pic [Re: Mastershake340] #948296
03/12/11 03:56 PM
03/12/11 03:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That car is
Re: 71 challenger side pic [Re: Mastershake340] #948297
03/13/11 12:34 PM
03/13/11 12:34 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
the emblems are in the correct location on the fender in your pic but are they a bit too far back toward the door ? Im just tryin to get a good measurment for my 71 befor I install the emblems. Do you have a closer pic of the fender ??
Re: 71 challenger side pic [Re: yella71] #948298
03/13/11 01:01 PM
03/13/11 01:01 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
I need a pic of the side of a 71 challenger showing the front fender with the challenger script............as far as I can tell my fenders are from a 70 with the emblems are ubove the body line.
Is your car built in August or early September 1970? If so, the 1970 fenders may be correct for your car, and those emblems placed correctly. Even though you have a 1971 model, it might have left over fenders from 1970.
Picture of original 1971 Challenger built September 8, 1970.
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: 71 challenger side pic [Re: cudaized] #948299
03/13/11 01:17 PM
03/13/11 01:17 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Early August 1970. I was informed that it is original sheet metal.
cudaized.com
Re: 71 challenger side pic [Re: cudaized] #948300
03/13/11 01:29 PM
03/13/11 01:29 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
October 30, 1970 Original sheet metal JH27N1B
cudaized.com
Re: 71 challenger side pic [Re: cudaized] #948301
03/13/11 01:36 PM
03/13/11 01:36 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
This one was from and original owner, 60,000 mile car.
December 17, 1970
cudaized.com
Re: 71 challenger side pic [Re: cudaized] #948302
03/13/11 01:43 PM
03/13/11 01:43 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
January 21, 1971
Original owner was selling it in 2006....27,165 original miles. Most likely the original fender (with original dents )
cudaized.com
Re: 71 challenger side pic [Re: cudaized] #948303
03/13/11 01:53 PM
03/13/11 01:53 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
There are more, but you get the idea.
For those of you following this thread: Does anyone know why most 1971 Challengers do not have those emblems on the fenders?
It seems that I have more pictures of no emblem fenders, then those with emblems.
Re: 71 challenger side pic [Re: cudaized] #948304
03/13/11 01:56 PM
03/13/11 01:56 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
August 10, 1970
Re: 71 challenger side pic [Re: cudaized] #948305
03/13/11 02:11 PM
03/13/11 02:11 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought in 71 they went to the adhesive stick on Challenger emblems. Maybe on original cars that have fallen off? And on repainted cars there are no holes to fill, so they just leave them off. Just a WAG.
Re: 71 challenger side pic [Re: Mastershake340] #948306
03/13/11 02:17 PM
03/13/11 02:17 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
First pic is not 100% either; The R/T badge is not needed as it already has the R/T Stripe.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: 71 challenger side pic [Re: autoxcuda] #948307
03/13/11 02:32 PM
03/13/11 02:32 PM
NORTHERN VA
NORTHERN VA
Yes ALL 71s had Challenger emblems on the fenders but if you got a 71 RT with stripes you usually did not get the RT badges on the fenders. In my pic above I have not installed the Challenger emblems yet until I get the correct measurements from a orig car.
Re: 71 challenger side pic [Re: THESHAKERPROJECT] #948308
03/13/11 02:41 PM
03/13/11 02:41 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Found this for stick on emblems.
Sorry. Can't seem to find any close up pictures...
Re: 71 challenger side pic [Re: cudaized] #948309
03/13/11 09:13 PM
03/13/11 09:13 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
Sept 70 build
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
