Headers and aluminum heads, question #948281
03/11/11 09:24 AM
03/11/11 09:24 AM
It's a dry heat
gtx6970 Online content OP
gtx6970  Online Content OP
It's a dry heat
I know this might be better asked in the race forum but thought to give it a try here 1st.
I need to attach the TTI headers to the aluminum Indy Cyl heads, and wondered if using stainless to attach them would be better for corrosion protection as opposed to simple plated steel ?
Re: Headers and aluminum heads, question [Re: gtx6970] #948282
03/11/11 10:39 AM
03/11/11 10:39 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It wouldn't be a bad thing , I'd also put something on the threads like never seize ....
Re: Headers and aluminum heads, question [Re: JohnRR] #948283
03/11/11 03:14 PM
03/11/11 03:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use antisieze on all my bolts and nuts.I run SS bolts on my intake with Stealth heads.I run studs in the exhaust even though they are dry holes.Rocky
Chrysler Firepower
Re: Headers and aluminum heads, question [Re: gtx6970] #948284
03/11/11 03:17 PM
03/11/11 03:17 PM
Kirkland, Washington
Pacnorthcuda Offline
If AT ALL possible...use studs, not bolts!
Re: Headers and aluminum heads, question [Re: Pacnorthcuda] #948285
03/11/11 04:31 PM
03/11/11 04:31 PM
Baltimore, MD
3
397STROKER Offline
super street
397STROKER  Offline
super street
3
Baltimore, MD
Be sure to antiseeze on SS bolts into Aluminum. Straight SS with Aluminum can seeze together due to some kind of chemical reaction. Don't ask me how I know.
Re: Headers and aluminum heads, question [Re: 397STROKER] #948286
03/11/11 04:33 PM
03/11/11 04:33 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Use some antisieze and you won't have any problems. I have stainless header bolts on my hemi and 440, both aluminum headed.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Headers and aluminum heads, question [Re: an8sec70cuda] #948287
03/11/11 08:15 PM
03/11/11 08:15 PM
IN
ahy Offline
ahy  Offline
IN
Anti-seize on plated bolts will work fine also. From the standpoint of function and durability the plated steel are just as good or better than SS because they don't have as much reaction with aluminum. Use SS for appearance.
Re: Headers and aluminum heads, question [Re: ahy] #948288
03/11/11 10:53 PM
03/11/11 10:53 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
X6 on the anti-sieze
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Headers and aluminum heads, question [Re: ahy] #948289
03/11/11 11:01 PM
03/11/11 11:01 PM
It's a dry heat
It's a dry heat
sounds good.
I ck local availability this weekend on either one
Thanks all
Re: Headers and aluminum heads, question [Re: gtx6970] #948290
03/12/11 12:32 AM
03/12/11 12:32 AM
rhode island
bomber1965 Offline
bomber1965  Offline
rhode island
high temperature anti-seize
Re: Headers and aluminum heads, question [Re: bomber1965] #948291
03/12/11 10:36 AM
03/12/11 10:36 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
If you don't use anti seize, you will be putting in heli coils after removing them a few times.
