Help me make a header gasket choice #94773
07/26/08 06:54 AM
07/26/08 06:54 AM
Hunt Valley, Maryland
1fastrunner Offline OP
I have a small exhaust leak on my passenger side and I have to remove my driver side to change out the starter. I have Hooker Headers and I'd like some help choosing some gaskets that will best help eliminate the leaks I'm currently having.
Thanks,
Re: Help me make a header gasket choice [Re: 1fastrunner] #94774
07/26/08 07:24 AM
07/26/08 07:24 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I've had good luck with the mr gasket ultra seals, they seemed to work for me when the cheap white paper gaskets wouldn't. What kind are you using now? If you have had a leak as long as that header has been on, you might consider a remflex ($) gasket which should seal anything. Or some people use red RTV only.
Re: Help me make a header gasket choice [Re: 1fastrunner] #94775
07/26/08 08:23 AM
07/26/08 08:23 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I've tired a few, but the one that flat stops leaks is Remflex.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Help me make a header gasket choice [Re: Junky] #94776
07/26/08 09:08 AM
07/26/08 09:08 AM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Absolutely. I will never buy another brand except for these.
Re: Help me make a header gasket choice [Re: HemiStan] #94777
07/26/08 10:39 AM
07/26/08 10:39 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
DITTO!!!
Re: Help me make a header gasket choice [Re: 1fastrunner] #94778
07/26/08 11:37 AM
07/26/08 11:37 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
How about NO Gasket ! I used Permatex Ultra High Temp Copper Silicone. If your flanges are good, clean and strait, head surface the same, it works !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Help me make a header gasket choice [Re: doctor_mopar] #94779
07/26/08 05:38 PM
07/26/08 05:38 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Ultra copper works great but remflex is the way to go.
Re: Help me make a header gasket choice [Re: Y3 70 BEE] #94780
07/26/08 05:56 PM
07/26/08 05:56 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
REMFLEX, problem solved.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: Help me make a header gasket choice [Re: 1fastrunner] #94781
07/26/08 08:09 PM
07/26/08 08:09 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
i like the Percy's aluminum.
Re: Help me make a header gasket choice [Re: ohiodemon] #94782
07/26/08 09:44 PM
07/26/08 09:44 PM
My dilemma is: it might only be a temp fix. I'm replacing my starter and wanting to fix a leak on the other side. I'm also contemplating pulling the motor for a rebuild. I've checked the pricing on the Remflex, and it seems like the best long term solution. It's a bit pricey for a quick, temporary fix. I still need to make some decisions.
Re: Help me make a header gasket choice [Re: 1fastrunner] #94783
07/26/08 10:03 PM
07/26/08 10:03 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I recommended remflex to 2 mopar buddies- they did not like the price a but bought them none the less. They both are now Remflex customers for life. Quickie cheap TEMPORARY fix is the cheapo paper gasket with a bead of the permatex on both sides of gasket.
Keep old mopars alive.
Re: Help me make a header gasket choice [Re: 2boltmain] #94784
07/26/08 10:07 PM
07/26/08 10:07 PM
Where's the best place to purchase it a get the best price?
Re: Help me make a header gasket choice [Re: 1fastrunner] #94785
07/26/08 10:20 PM
07/26/08 10:20 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Remflex.com.I called and ordered over the phone.ONLY WAY TO GO!!!!!!!!!!
Re: Help me make a header gasket choice [Re: 1fastrunner] #94786
07/27/08 01:38 AM
07/27/08 01:38 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
The local speed shop have em', and I've seen them at an auto store, but can't remember which one. I think it was CarQuest.
Re: Help me make a header gasket choice [Re: Exit1965] #94787
07/27/08 09:56 AM
07/27/08 09:56 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
I use Ultra Seal too and no problems.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Help me make a header gasket choice [Re: MY340] #94788
07/27/08 02:49 PM
07/27/08 02:49 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We have run Mr Gasket Ultra.One set was on for at least 6 years and no leaks.Evewn have reused them.At 15 bucks a set I can replace mine every 6 or 7 years and still come out ahead.The coppers leaked like a sieve even with my TTIs.Rocky
Chrysler Firepower
Re: Help me make a header gasket choice [Re: 1fastrunner] #94789
07/27/08 03:12 PM
07/27/08 03:12 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
With Mr. Gasket Ultra Seals, I had to "punch out" the mounting holes on the passenger side of my engine so that the gasket would line up properly and seal. I then got the Remflex gaskets set and put them on that same side no changes and they sealed up first shot. Bought them at a local NAPA shop, but you may have to hunt around to find someone that carries them locally or just buy online. They are indeed a great gasket. LOTS of crush to em to fill all those nasty imperfections.
Re: Help me make a header gasket choice [Re: Alikazam] #94790
07/28/08 09:59 PM
07/28/08 09:59 PM
I ordered my Remflex yesterday. I found the big block exhaust gaskets on Amazon.com for $28.40 including shipping.
Re: Help me make a header gasket choice [Re: HemiStan] #94791
07/28/08 10:58 PM
07/28/08 10:58 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
1000%
