Who Can Anodize Trim? #947687
03/10/11 12:32 PM
03/10/11 12:32 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
I had Mike Voth at All Trim redo my 65 Fury I 2 door molding.
Unfortunately the passenger side quarter molding is a couple of inches too long to fit in his anodizing tank. The molding is around 93 inches long and 3/4 inches wide.
So I need to find a vendor that can bright anodize the piece for me. It is fully polished and ready for dipping.
Who is reputable and can do this one piece for me?
Re: Who Can Anodize Trim? [Re: markz528] #947688
03/10/11 01:37 PM
03/10/11 01:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Why would he not disclose that before doing every other piece? All the trim should go in the same chemical tank or it likely will never match...
Re: Who Can Anodize Trim? [Re: 1_WILD_RT] #947689
03/10/11 02:15 PM
03/10/11 02:15 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Yeah I know....... It was ugly. He thought it would go and when he went to put it in the tank it wouldn't go and knocked one of the small pieces in the tank so its gone forever....... These were all NOS pieces.
Can't change it, so just need to find someone who can do the last piece and go forward.......
Re: Who Can Anodize Trim? [Re: markz528] #947690
03/10/11 02:42 PM
03/10/11 02:42 PM
P
PaddleOn Offline
PaddleOn  Offline
P
Randy, bluntly! you have no clue as to your opinion. also, like everyone does when complaining on moparts he left out some of the story. (I don't think was complaining just looking for options, but you jumped in with your drama without knowing anything about it rather than trying to help)...
1.) had i known it wasn't going to fit i wouldn't have taken it in!
2.) it was not realized until after the parts were all racked and ready run and going into the tank that it was not going to fit. i even re-racked it on another rack and tried to get it to fit by itself.
3.) why did i take it in? because i used to run these long parts all the time for the 60's impala crowd, but made some changes in the tank for air line configuration and I lost 1.5 inches of space, but had not ran any of the longer parts since then... so without realizing the space change would now limit parts (as the changes were minor), longer parts over 90 no longer fit.
4.) when i run parts it is often that not all the parts fit on the same rack, so are therefore ran at different times on different racks, even on different days.. so the parameters in which they are run can vary by a few minutes, a few degrees in temperature, by a few amps or volts per part, and even chemical make up depending on many factors...
so your opinion that parts have to be ran at the same time is a lack of your knowledge and theory on the process, and BS!
5.) he was offered an option to get it done elsewhere, but because of the commercial nature of shops reluctantly doing auto trim didn't like the expressed warranty that, it might end up with rack scratches/ damage and that there are no guarantees or warranty. neither of us were comfortable with that but it had to be disclosed (and he made his decisions), and was part of the risk every time i did something prior to putting in my own tanks (the whole reason i put in my own tanks, not mention the other guys high prices), only to have to implement the same restriction here (for loss in tanks) as i wasn't about to dive into a hot acid bath to save any thing. (this is all the behind the scenes stuff you people wanting this done, have no clue about what goes into doing this. it's not just here it's everywhere, with everyone that does this).
5a). so why he asking about it here? when he had it all figured out to go with special T's maybe it because special T's charges ridiculous prices for the process and now he doesn't now want to pay the price? or maybe now Special T's wont take it in? (BTW the price for the above option was not anywhere near what he was quoted for the alternative offered).
6.) does it bother me? yes! this job was one of those jobs that had to be perfect, and it never fails when that is the requirement, something will go wrong or it will take ten times the amount of effort compensated for to get the end result, without additional compensation.
7.) not to worry for all those that will inevitably get involved in the drama, and say wow i would never use that guy, etc,
don't worry, I am no longer doing retail minded customer trim!
BTW the parts on this grille were all anodized at different times and places, one was even anodized in china, and the minimal differences are no different than the way the parts come from the factory.... do you think they took the time to make sure every part had the same reflective hue etc, and matched from part to part?
Re: Who Can Anodize Trim? [Re: PaddleOn] #947691
03/10/11 03:18 PM
03/10/11 03:18 PM
washington
AB&E Offline
AB&E  Offline
washington
It is what it is.xxxx happens
moparts is very condemning.
Re: Who Can Anodize Trim? [Re: AB&E] #947692
03/10/11 04:15 PM
03/10/11 04:15 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Just to be perfectly clear, stuff happens and I am very happy with the work Mike did. He has done great work for me many times now, and I just am looking for alternatives to Special T. He is not honoring a verbal commitment.......
Re: Who Can Anodize Trim? [Re: markz528] #947693
03/10/11 05:30 PM
03/10/11 05:30 PM
washington
AB&E Offline
AB&E  Offline
washington
No PUN intendeed. but if you have been working on cars as long as I have its always something nothing is 100% except one thing & we all know what it is
Re: Who Can Anodize Trim? [Re: AB&E] #947694
03/10/11 09:15 PM
03/10/11 09:15 PM
MI
AfterHoursResto Offline
MI
Never used them yet but look these guys up: Charlotte Anodizing Products, Inc. They are located in Charlotte, MI and have a 20 foot long tank.
Roman Sobilo
Re: Who Can Anodize Trim? [Re: PaddleOn] #947695
03/10/11 09:24 PM
03/10/11 09:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not looking to get into a pissing match with you Mike.. But honestly there are significant variations in the grill surround trim you posted due to the mix & match nature to the parts... Yes you can run parts in your tanks at varying times & they should match closely enough to satisfy most customers, however have someone else who's tanks chemical make-up is somewhat different run the parts at a different voltage & for a longer or shorter duration & the results won't be the same.... Yes from the factory there were variations, different suppliers, different operators, any of a number of variables... But a man doesn't bring his NOS parts to you for refinishing to be told about "acceptable variations".... Acceptable variations is a very vague term, what one man finds acceptable another will find completely unacceptable... If I shop my trim repair work by price than I need to be willing to accept work like the picture you posted.... When I step up & pay big $$ to a guy that proclaims his stuff can take judging on a show field than what I consider acceptable variation drops substantially.. & the grille you posted sure wouldn't cut it.... BTW I talked to a guy thats worked on enough show level trim & verified what I stated was correct about what you say I don't have a clue about...
BTW Why the new name??
Why are so many people looking for a new trim guy? Funny you say you had problems with parts coming back from being anodized with scratches.. I've heard you aren't the only one to experience that problem....
Re: Who Can Anodize Trim? [Re: 1_WILD_RT] #947696
03/10/11 09:34 PM
03/10/11 09:34 PM
Boston Ma
Hamtramck Offline
Hamtramck  Offline
Boston Ma
69 roadrunner conv. 4spd B5/X9
Re: Who Can Anodize Trim? [Re: markz528] #947697
03/10/11 09:56 PM
03/10/11 09:56 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
You may also try Matt at MCB. He did a nice job one my hood trim and headlamp bezels.
Joe
65 Barracuda
70 Challenger
Re: Who Can Anodize Trim? [Re: jrwoodjoe] #947698
03/19/11 10:30 PM
03/19/11 10:30 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Thank you very much for those that responded. I talked with Matt at MCB and he was great. Charlotte does his anodizing.
I called Charlotte, and unlike Special T they were great to deal with. Gave me a great price and I got it back 7 days after I sent it back.
Piece looks great! I can't tell any difference between this piece and the other pieces. I am very pleased!
Re: Who Can Anodize Trim? [Re: PaddleOn] #947699
03/20/11 10:19 AM
03/20/11 10:19 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
For those of us in the restoration biz, in one form or another, no truer words have been spoken.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Who Can Anodize Trim? [Re: sixpackbee] #947700
03/21/11 07:19 PM
03/21/11 07:19 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Should a paying customer expect anything less than a perfect job for his money or are there different levels of perfect?... such as really perfect, perfect, less than perfect, not even close to perfect? Just wondering.
Re: Who Can Anodize Trim? [Re: badblack68] #947701
03/21/11 08:17 PM
03/21/11 08:17 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
There are different levels of any type of work short of the medical field. A customer paying Earl Shibe prices should expect less than perfection. Driver job for driver prices, Autorama job for Autorama prices. Do you really think I'd put the hours and pain into a absolute show quality paint job when the customer wanted and paid for a driver type job? I'd out of biz pretty darn quick. Can't live on 3/hr.
1959 Bugeye Sprite
1971 MG Midget
Re: Who Can Anodize Trim? [Re: 1_WILD_RT] #947702
03/21/11 08:32 PM
03/21/11 08:32 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Does anyone actually think that Chrysler had every part anodized in the same tank on a car when they were new?
They were mass produced parts on mass produced cars.
Re: Who Can Anodize Trim? [Re: sixpackbee] #947703
03/21/11 08:48 PM
03/21/11 08:48 PM
badblack68 Offline
badblack68  Offline
My question was pertaining to anodizing trim. I wasn't leaning towards any sarcasm, I was just curious to know if there were different levels of trim restoration. I realize that pricing will vary depending on who's doing the work, my question was about levels of trim restoration. Are there different quality levels and different pricing for those levels. I always thought anodizing was a process that didn't have a wide spectrum of variation.
Re: Who Can Anodize Trim? [Re: SNK-EYZ] #947704
03/21/11 09:14 PM
03/21/11 09:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes & if I were looking to have my car look equal to mass produced I wouldn't pay the price Mike @ Alltrim charges... If you are looking for mediocre then find a cheap vendor... You don't step-up to high $$$ suppliers unless your looking for higher quality work....
Re: Who Can Anodize Trim? [Re: badblack68] #947705
03/21/11 09:18 PM
03/21/11 09:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
One of the keys to good brite dip is good prep work getting the flaws worked out of the trim prior to going in the tank....Another portion is maintaining the chemicals in the tank plus finding the proper current flow & duration for the best most consistent result..
Re: Who Can Anodize Trim? [Re: 1_WILD_RT] #947706
03/21/11 10:50 PM
03/21/11 10:50 PM
MrNormTA Offline
MrNormTA  Offline
Well I stepped up to the level when I bought one of his high dollar grills from him on ebay. Lets just say that I didn't get the grill in the picture. I was shocked when I unwrapped it to find A repaired end that was welded with all kinds of grinding marks and hammer marks on the back. When installed you can see the repair(welded area)very easily. Very noticeable repair from the topside. The rest of the grill is beautiful but what a jackwagon to deal with this dishonest seller!!!!!! Of course his superior mentality and craftmanship was beyond reproach when I asked why the ad and pictures didn't show the repair area. How dare I, he's Mike from Alltrim! Refund, are you kidding, only if you send it back within 3 days. West coast to Indiana and no refund for shipping. I can see he's got talent, for sure, but at what cost?
