8 3/4 builders in Indy??? #947359
03/09/11 09:10 PM
03/09/11 09:10 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
I'm looking for a gear change and a rebuild for my 8 3/4 center section and am looking for someone in or near Indy to do the job. I've done most everything except rebuild rearends and would feel better getting this done right the first time by someone who knows what he's doing. I've talked to a couple of guys who as usual do a lot of GM/Ford stuff, but not Mopar. I'm sure they aren't much different but would feel better with someone who's familiar with Mopars. I'm on the east side if that helps, but will travel!
Thanks in advance!
Re: 8 3/4 builders in Indy??? [Re: slowpoke] #947360
03/10/11 10:11 AM
03/10/11 10:11 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Anyone???
Re: 8 3/4 builders in Indy??? [Re: slowpoke] #947361
03/10/11 11:22 AM
03/10/11 11:22 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The best advice I could give you is,you are not that far from Moser Engineering.I would look into that if nobody else can help.
Keith
Re: 8 3/4 builders in Indy??? [Re: Dunnuck Racing] #947362
03/10/11 02:30 PM
03/10/11 02:30 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Contact Rick, Blown71X
https://board.moparts.org/ubbthreads/show...part=1&vc=1
He might be able to help you out.
Re: 8 3/4 builders in Indy??? [Re: slowpoke] #947363
03/10/11 02:35 PM
03/10/11 02:35 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Check with Ben at Promax. He would know someone if his shop can't.
sales@promaxcarbs.com
Re: 8 3/4 builders in Indy??? [Re: YO7_A66] #947364
03/11/11 12:44 AM
03/11/11 12:44 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Thanks will check them out!
Re: 8 3/4 builders in Indy??? [Re: slowpoke] #947365
03/12/11 12:40 PM
03/12/11 12:40 PM
Indy
mike Offline
mike  Offline
Indy
Hi Keith, I am on the east side of Indy also.
I have done my own, but also have a friend who does transmisson work for a living and has done my gears in the past, before i tried it myself. If you want to do your own, i can help you out. It's really not that hard.
let me know,
Mike
moparman68@sbcglobal.net
'69 Dart
'14 Ram 1500
'09 Journey R/T
Re: 8 3/4 builders in Indy??? [Re: mike] #947366
03/12/11 02:01 PM
03/12/11 02:01 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
Rick Allison at A&A transmission did the 8 3/4 I had in a Charger, quality was outstanding.
And Blown71X would also be a good one to contact.
'71 Duster
