How much power: Stage V hemi heads and pump gas #947254
03/09/11 07:04 PM
03/09/11 07:04 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
How much power would you say could be made with a set of CNC ported HEMI Stage V heads, 4,5 bore block, 4,375" stroke crank?
This would be pump gas and naturally aspirated.
I also have 2,25" headers.
I dont have the heads but was thinking about the replacement stle Stage V HEMI Heads. I know they make some other more serious heads but then you have ti use custom headers and more expensive rockers I think which would go beyond my budget...
Re: How much power: Stage V hemi heads and pump gas [Re: domingo] #947255
03/09/11 07:48 PM
03/09/11 07:48 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
just a guess 700?
home of the
Sox and Martin Hemi Duster
Re: How much power: Stage V hemi heads and pump gas [Re: domingo] #947256
03/09/11 07:50 PM
03/09/11 07:50 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
what kind of car is it going in stock looking show car?,race car?prostreet? how fast do you want to go?
MOPAR OR NO CAR
Re: How much power: Stage V hemi heads and pump gas [Re: hemigod426] #947257
03/09/11 08:00 PM
03/09/11 08:00 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
into this one. ALL OUT RACE.
67 all steel save for the hood which is glass with a 68 SS A body scoop.
gutted interior, lexan save for the rear winow.
Stock chassis, still has stock inner fenders.
ford 9" rear, cal tracks with monoleafs.
CRT transbrake 727 rollerized.
tubbed, trunk lid is still and hinged still works.
33" x 10,5" slicks.
disc brakes all around.
FULL CAGE and im also gonna make a funny car cage in it, for safety's sake.
Still I want pump gas because racing gas is a hassle to get down here....aviation gas is all we got and it is a pain to get it.....not worth bothering.
Re: How much power: Stage V hemi heads and pump gas [Re: domingo] #947258
03/09/11 08:02 PM
03/09/11 08:02 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Its all in the heads. Id say 700-750 is easy to obtain. Get the heads to flow 425-450cfm and it will run like a raped ape.
Re: How much power: Stage V hemi heads and pump gas [Re: domingo] #947259
03/09/11 08:06 PM
03/09/11 08:06 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
I built two almost identical 511" HEMIs at the same time for two different guys. They both had BOX STOCK Stage V engineering standard port location heads and they were both pump gassers. One was FAST Fuel injected and the other was a two four barrel carb deal. Both used the stage V dual quad manifold as well and they both made basically the same power on the dyno at around 720. They both had very mild camshafts with around 248 @ .050 duration and .650 or so lift.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: How much power: Stage V hemi heads and pump gas [Re: PUNK] #947260
03/10/11 09:37 AM
03/10/11 09:37 AM
pa
572charger Offline
572charger  Offline
pa
my 606 cuin hemi with semi ported stage Vs [flow 450 at 700 lift] pumpgas motor 11.7 to 1 comp with a 282/291 at.050 720 /690 lift comp roller, is makin 850 to 900 hp based on a et of 9.60s at 142 mph at 3910 lbs with me in it my heads were cnc ported by raybarton they called it a street port put my motor in your car it should go 8.90s with out a problem !!!! NICE CAR !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: How much power: Stage V hemi heads and pump gas [Re: 572charger] #947261
03/10/11 10:41 AM
03/10/11 10:41 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks!!!!
I have to start saving my pennies for this build!
Re: How much power: Stage V hemi heads and pump gas [Re: domingo] #947262
03/10/11 10:42 AM
03/10/11 10:42 AM
an8sec70cuda Offline
The Stage V replacement heads when CNC ported by MCH are a little better than my MP heads (also CNC'd by MCH) and I'm making over 800 hp on pump gas. I do have a 4.5" stroke though.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How much power: Stage V hemi heads and pump gas [Re: an8sec70cuda] #947263
03/10/11 06:07 PM
03/10/11 06:07 PM
Marengo, IL
572DartPost Offline
572DartPost  Offline
Marengo, IL
On 91 octane we made over 900 hp and still climbing at only 6500 rpm with street replacement stage v heads by MCH, a used super stock intake, two old 770 holleys, and a street roller cam in a 572.
Re: How much power: Stage V hemi heads and pump gas [Re: 572DartPost] #947264
03/10/11 08:50 PM
03/10/11 08:50 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
spill the beans!
Re: How much power: Stage V hemi heads and pump gas [Re: domingo] #947265
03/10/11 09:52 PM
03/10/11 09:52 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I'd like to know the cam spec.'s
Re: How much power: Stage V hemi heads and pump gas [Re: rowin4] #947266
03/11/11 12:00 AM
03/11/11 12:00 AM
Marengo, IL
572DartPost Offline
572DartPost  Offline
Marengo, IL
Cam is solid roller around 275 at 50 and .700 lift. Used 2 1/8 headers on the dyno, the 2 1/4 on it now would have probably made more, so would bigger carbs. Carbs aren't on correctly in pic.
Re: How much power: Stage V hemi heads and pump gas [Re: 572DartPost] #947267
03/11/11 12:18 AM
03/11/11 12:18 AM
rowin4 Offline
rowin4  Offline
Lookin good what you putting it in? and thanks for the cam info
Re: How much power: Stage V hemi heads and pump gas [Re: domingo] #947268
03/12/11 07:14 PM
03/12/11 07:14 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
With a very mild roller (under 600 lift), 10.5 comp, Stage V intake with two 650 carbs, and CNC ported Stage V heads, I got 658 at 6500rpm. 472CID
