Re: How much power: Stage V hemi heads and pump gas
[Re: hemigod426]
#947257
03/09/11 08:00 PM
03/09/11 08:00 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
into this one. ALL OUT RACE.
67 all steel save for the hood which is glass with a 68 SS A body scoop.
gutted interior, lexan save for the rear winow.
Stock chassis, still has stock inner fenders.
ford 9" rear, cal tracks with monoleafs.
CRT transbrake 727 rollerized. tubbed, trunk lid is still and hinged still works.
33" x 10,5" slicks.
disc brakes all around.
FULL CAGE and im also gonna make a funny car cage in it, for safety's sake.
Still I want pump gas because racing gas is a hassle to get down here....aviation gas is all we got and it is a pain to get it.....not worth bothering.
[Re: domingo]
#947259
03/09/11 08:06 PM
03/09/11 08:06 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
I built two almost identical 511" HEMIs at the same time for two different guys. They both had BOX STOCK Stage V engineering standard port location heads and they were both pump gassers. One was FAST Fuel injected and the other was a two four barrel carb deal. Both used the stage V dual quad manifold as well and they both made basically the same power on the dyno at around 720. They both had very mild camshafts with around 248 @ .050 duration and .650 or so lift.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: PUNK]
#947260
03/10/11 09:37 AM
03/10/11 09:37 AM
Posts: 1,629 pa
572charger
pa
my 606 cuin hemi with semi ported stage Vs [flow 450 at 700 lift] pumpgas motor 11.7 to 1 comp with a 282/291 at.050 720 /690 lift comp roller, is makin 850 to 900 hp based on a et of 9.60s at 142 mph at 3910 lbs with me in it my heads were cnc ported by raybarton they called it a street port put my motor in your car it should go 8.90s with out a problem !!!! NICE CAR !!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: domingo]
#947262
03/10/11 10:42 AM
03/10/11 10:42 AM
Posts: 13,406 Marion, South Carolina [><]
an8sec70cuda
The Stage V replacement heads when CNC ported by MCH are a little better than my MP heads (also CNC'd by MCH) and I'm making over 800 hp on pump gas. I do have a 4.5" stroke though.
[Re: 572DartPost]
#947264
03/10/11 08:50 PM
03/10/11 08:50 PM
domingo
EL Master
EL Master
Lima, Peru
On 91 octane we made over 900 hp and still climbing at only 6500 rpm with street replacement stage v heads by MCH, a used super stock intake, two old 770 holleys, and a street roller cam in a 572.
spill the beans!
[Re: domingo]
#947268
03/12/11 07:14 PM
03/12/11 07:14 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
How much power would you say could be made with a set of CNC ported HEMI Stage V heads, 4,5 bore block, 4,375" stroke crank?
This would be pump gas and naturally aspirated.
I also have 2,25" headers.
I dont have the heads but was thinking about the replacement stle Stage V HEMI Heads. I know they make some other more serious heads but then you have ti use custom headers and more expensive rockers I think which would go beyond my budget...
With a very mild roller (under 600 lift), 10.5 comp, Stage V intake with two 650 carbs, and CNC ported Stage V heads, I got 658 at 6500rpm. 472CID
