Which is better: B1 heads or Indy 440-1 heads? #947024
03/09/11 11:22 AM
03/09/11 11:22 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Which heads are better?
And does Indy offer something even better than the 440-1 heads?
Domingo
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: domingo] #947025
03/09/11 11:53 AM
03/09/11 11:53 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I think Indy has some wedge heads that are similar to the 440-1 heads only that they have bigger volume ports? Or is the whole port configuration different?
I think B1 heads have considerably larger ports than the 440-1 heads...right?
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: domingo] #947026
03/09/11 11:56 AM
03/09/11 11:56 AM
tboomer Offline
tboomer  Offline
Domingo...What is the intened usage and what are you building? That may get ya some answers!
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: tboomer] #947027
03/09/11 12:16 PM
03/09/11 12:16 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Just a generic question. Im not building anything at the present time....
Im just laying in bed with a broken knee from surfing....
I have a HEMI megablock though and a 4,375" billet Bryant crank.
Id like to build a low manteniance (reliable) pump gas race engine with that at some point though.
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: domingo] #947028
03/09/11 12:19 PM
03/09/11 12:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You might want to consider what intakes are avalible
also before going in anyone direction
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: MR_P_BODY] #947029
03/09/11 12:26 PM
03/09/11 12:26 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Right. From what I see the Indy intakes are always the best cast intakes....I doubt the B1s have many choices as far as intakes goes.
I was very impressed about Muscle Motors pump gas King Krate B1 engine. I think its 1000 hp on pump gas for like 16k? Thats real good bang for the buck!
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: MR_P_BODY] #947030
03/09/11 12:27 PM
03/09/11 12:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well with a Hemi block that kinda narrows it down. Predator and Hemi heads woudl be the only way to go.
As for the original question the B1 head has the best HP potential. If you can make 800+hp from a basic B1 combo you are doing something wrong. Getting to 800 from a -1 while not necessarily difficult will require a bit more thought.
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: Al_Alguire] #947031
03/09/11 12:36 PM
03/09/11 12:36 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I thought you could get B1s with a hemi bolt patttern....
Still B1s are easier and cheaper to get power from than lets say, some CNC porteds Stage V replacement HEMI heads?
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: domingo] #947032
03/09/11 12:40 PM
03/09/11 12:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think there is a B1TS head available in a Hemi pattern, but that is an entirely different animal.
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: domingo] #947033
03/09/11 12:43 PM
03/09/11 12:43 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
You will be surprised at what you can get out of StageV heads. Great bang for the buck.
RIP Monte Smith
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: CompWedgeEngines] #947034
03/09/11 12:49 PM
03/09/11 12:49 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, given what I already have, I was wondering how much power I could make on pump gas, CNC ported Stage V hemi heads, and a 4,5 bore megablock and 4,375 stroke (I think that comes up to 540). What would be the best combo of the other parts I need (intake, carbs, cam, etc.?). I already have 2.25" hemi headers for my A Body race car
Would a b1 setup have an edge over the above? Will it be cheaper to build? I can always trade my hemi megablock for a wedge....my headers would be useless though, Id have to fab new custom headers for my a body with stock inner fenders (arrghhh)
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: domingo] #947035
03/09/11 01:04 PM
03/09/11 01:04 PM
gregsdart Offline
gregsdart  Offline
The 4.5 by 4.375 is 557(?) inches. A good build with 440-1 heads will make very good torque down low due to smaller ports than the B1. Up to about 800 hp with that many cubes port velocity should make the 440-1 a better choice for a reliable low rpm race motor. You should be able to shift at 6800 with a torqueflite and be in the sweet spot. The B1 will make more power but may need more rpm to do so. I shift my 528 with 440-1` heads at 7200, making 850+ hp.
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: domingo] #947036
03/09/11 01:20 PM
03/09/11 01:20 PM
I have had all three heads, Stage V on a pump gas blown hemi, CNC ported 440-1 on a pump gas motor and I do have a set of B1 not used yet. The B1 flow 430 cfm at .700, .800 and above, the 440-1 flow 370 at .700 and the ported Stage V flowed a tiny bit better than the B1s did If I was making the choice you have I would go with the Stage V based on the parts and intended usage nothing like the WOW factor of a Hemiroid
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: Cab_Burge] #947037
03/09/11 01:28 PM
03/09/11 01:28 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
The b1-TS heads are a hemi bolt pattern. Although they are nothing you would be building a pump gas engine around.
I am almost 100% sure no other b1 heads are the hemi bolt pattern.
Also for indy none of their wedge heads (except Predator) are a hemi bolt pattern.
Since you already have the block I think the Stage 5 heads are the best way to go.
Re: Which is better: B1 heads or Indy 440-1 heads? [Re: Diablo] #947038
03/09/11 04:31 PM
03/09/11 04:31 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
the best 440-1 flows 400 cfm and the best B1(not the TS) flows 470 cfm. Its true you have to use the B1 intake...but its about the best single four intake anyway. price wise they are about the same for the "package" ...Indy is about $3500 and you can get the B1 deal for around $3200 in the winter special. That said, if you want the biggest valve B1/MC it will cost another $900 for the Ti valves.
