one-man brake bleeder kit #946987
03/09/11 10:38 AM
03/09/11 10:38 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
I found this yesterday when I picked up my new master cylinder. Has anyone used one of these? I was going to gravity bleed the brakes, but then I saw this. What's anyone's experience with this or similar kit? I don't have any of my car buddies nearby to help with this before the weekend, so I'm on my own. I wanted to get this done tonight. I have already bench-bled the master cylinder.
Troy
Houston Mopar Connection Club
Re: one-man brake bleeder kit [Re: hemi68charger] #946988
03/09/11 10:46 AM
03/09/11 10:46 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Never used one of those. I do have a real pressure bleeder that I use which is worth it's weigh in gold.
OT a little. When I was teenager, I would get my girlfriend to pump the brakes while I bleed the brakes. Of couse she didn't understand what we we're trying to do and I would get all uptight doing it. We eventually got married and then divorsed.
20 years later we get back togeather and we are talking and she says she'll do anything for me except help me bleed brakes. Out of nowhere she says this. She said it sucked so bad when she tried to help me that she advised her 2 daughters to never help to bleed brakes. She remembered how stressed I made her while trying to bleed them.
I told her no worries now I have a pressure bleeder.
Good luck with yours, looks like you have the right tool for the job.
Re: one-man brake bleeder kit [Re: hemi68charger] #946989
03/09/11 10:47 AM
03/09/11 10:47 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I too am usually working as a one man band. I bought a similar kit a couple of years ago. It works great. No more brake fluid mess all over everything including the floor.
Re: one-man brake bleeder kit [Re: Challenger 1] #946990
03/09/11 11:27 AM
03/09/11 11:27 AM
Houston, Tx
Houston, Tx
...I would get my girlfriend to pump the brakes while I bleed the brakes. Of couse she didn't understand what we we're trying to do and I would get all uptight doing it. We eventually got married and then divorsed.
This is the exact reason I'm not asking Kim to help me.... Don't want her to even know I'm bleeding the brakes (or anything else on the car for that matter). I want to stay married and have a good day tinkering with my Daytona...
That's good to know. I was thinking about the hand-held vacuum pumps, but I would have had to order one and they are about $60 compared to this one at $8.
Troy
Re: one-man brake bleeder kit [Re: hemi68charger] #946991
03/09/11 01:44 PM
03/09/11 01:44 PM
michigan woods
imfixinmopars426 Offline
michigan woods
i made my own pressure bleeder,plate of aluminum,a rubber gasket w/ slot in center so psi will get to both sides of resevior,and a hose in the middle of the plate. put air psi in the hose through a regulator at 5-10 psi. start at zero,and crank it up slow. i use c clamps,or whatever to fasten the plate to the master cyl. bleed a few times and ck level...works great,im always by myself.
Re: one-man brake bleeder kit [Re: imfixinmopars426] #946992
03/09/11 01:47 PM
03/09/11 01:47 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I did the same exact thing years ago...used a metal plate with a piece of flat rubber glued to it to help seal to the master cylinder.
I do have a vacuum one too (mighty vac) setup that is good in alot of situations as well.
Re: one-man brake bleeder kit [Re: hemi68charger] #946993
03/09/11 01:58 PM
03/09/11 01:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
One word: Mityvac.
- Stu Harmon
Re: one-man brake bleeder kit [Re: hemi68charger] #946994
03/09/11 03:16 PM
03/09/11 03:16 PM
Cincinnati, Ohio
Cincinnati, Ohio
Is this a show and tell thread? If so here's mine.I got it for free 20+ years ago from a friend who was closing his shop. It was all rusty, and he thought it might blow up from rust. I took it apart and the rubber diaphram was in great shape. Painted it and installed a new hose. Had to buy the MC adapators. Been using it ever since and I am on my 3rd hose easy and just took it apart a year or 2 ago and repainted it again.
Top half holds a gallon of brake fliud and the bottem get's pressurized with shop air.(5-10PSI). Works slicker than snot on anything. I store it under pressure with brake fliud in it and it never get's contaminated. Makes it really easy to flush old fluid out and install new at the same time. Fast and sure, helps me make money with no come backs.
I just used it a week or 2 ago on this MC that goes on a forktruck.
Re: one-man brake bleeder kit [Re: feets] #946995
03/09/11 04:10 PM
03/09/11 04:10 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
One word: Mityvac.
You can get this at harbor freight for $40
http://www.harborfreight.com/mityvac-vacuum-pump-39522.html
Re: one-man brake bleeder kit [Re: None2Slow] #946996
03/09/11 04:28 PM
03/09/11 04:28 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
I have Speedbleeders on a couple cars. They are bleeder screws that have a small spring and check ball inside. The threads are teflon coated so you won't get air leaking past the threads. Just open it up and pump away. All popular sizes available. $7 each. They are great for a track car or for bleeding by yourself.
Speedbleeder Website
Re: one-man brake bleeder kit [Re: None2Slow] #946997
03/09/11 05:10 PM
03/09/11 05:10 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
One word: Mityvac.
I have had one of these for years. Cannot do without it. Makes brake bleeding EASY.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: one-man brake bleeder kit [Re: MOPARMIKE69] #946998
03/09/11 06:23 PM
03/09/11 06:23 PM
Flower Mound, TX, US
75dartcustom Offline
I use the one from Motive Products and it's fantastic!
Re: one-man brake bleeder kit [Re: MOPARMIKE69] #946999
03/09/11 09:28 PM
03/09/11 09:28 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
One word: Mityvac.
One small tip - before bleeding the brakes wrap the bleeders in a little teflon tape - helps prevent air from being pulled past the threads of the bleeder. I close the bleeder, pull a vacuum and then crack the bleeder screw, and it pulls the fluid right through.
Re: one-man brake bleeder kit [Re: Sixpak] #947000
03/09/11 10:50 PM
03/09/11 10:50 PM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
whats wrong with putting a rubber hose on the bleeder screw and putting the other end in a soda bottle with a bit of brake fluid covering the other end of the hose, open the bleeder screw then slowly pump the brakes?
i have been bleeding brakes this way for the last 20 years without problems.
best of all it doesn't cost you anything for the home made tool.
perception is 90% of reality
Re: one-man brake bleeder kit [Re: Mr T2U] #947001
03/09/11 11:03 PM
03/09/11 11:03 PM
BDW Online content
BDW  Online Content
I still have the wife pump the breaks.
How exactly do you use the MityVac?
Re: one-man brake bleeder kit [Re: BDW] #947002
03/10/11 01:18 AM
03/10/11 01:18 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
You use the little plastic jar with it, and pull a vacuum through it, and it sucks the air/brake fluid through the lines/caliper and fills the jar. Just empty it out before it gets to the top and gets sucked into the vac of course
Oh, and I used my mityvac to reverse bleed my clutch system, worked perfect for it as well!
Re: one-man brake bleeder kit [Re: Challenger 1] #947003
03/10/11 01:22 AM
03/10/11 01:22 AM
That's funny
Re: one-man brake bleeder kit [Re: Mr T2U] #947004
03/10/11 05:05 AM
03/10/11 05:05 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I've been doing that for years. Cheap and easy one man bleeding.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: one-man brake bleeder kit [Re: Mr T2U] #947005
03/10/11 05:58 AM
03/10/11 05:58 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
What do you mean whats wrong? Don't you want new tools? Its always a good reason to buy stuff. Yeah, I guess your way works too, but jeez, new stuff ROXXX
Re: one-man brake bleeder kit [Re: feets] #947006
03/10/11 11:06 AM
03/10/11 11:06 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
One word: Mityvac.
Just got this same one the other day.
Still don't know how to use it though...
