Re: 02 Grand Caravan check engine light
[Re: 68SportSatvert]
#946740
03/08/11 11:48 PM
03/08/11 11:48 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
What typically is thought of as a fuel cap code is actually a code to indicate a leak in the evap system.... The gas cap is part of that but so is many feet of vacuum hose, the fuel tank, a vapor storage tank... It won't effect drivability but if you have emissions testing it won't pass with a light on....
#946743
03/09/11 12:19 AM
03/09/11 12:19 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The way it's typically handled it to use a smoke generator to force smoke into the gas tank & pressurize the system... it will leak from the problem area.... A guy with Dodge dealer experience may know of a common problem area like a fitting that cracks.. Might try a google search for the failure code & your vehicle yr/make/model..
[Re: Wicked49670dart]
#946750
03/10/11 02:51 PM
03/10/11 02:51 PM
Posts: 1,377 Ohio
Todd
Ohio
Also check the evap test port (has a green cap on it the size of a valve stem cap) located between the air cleaner housing and the engine. The hoses that are on either side of the test port crack. Also take a good look at the fuel filler tubing from the gas cap to the fuel tank. They like to rust out especialy up around the end of the tube by the gas cap. ![](/ubbthreads/images/graemlins/Twocents.gif) By the way the evap canister is located on the left frame rail behind the front subframe and in front of the fuel tank.
[Re: Todd]
#946754
03/11/11 09:19 AM
03/11/11 09:19 AM
Posts: 515 Bolingbrook, IL
HemiRunner
super street
super street
Bolingbrook, IL
Common mini van evap problems are the LDP (leak detection pump) or lines. Evap canister site right under the steering rack on the cradle. Rack leaks fluid on top of it. Connections to canister are rubber & crack. Solenoid mounted to right front core support & has two lines coming off & need to be checked for cracks. One goes down towards the canister & other to the intake. Smoke & scanner are the best ways to find evap problems, but you checking all lines & connections are a good start. Also look at gas cap seal/o-ring. If dry & cracked could be the source as well.
Blown & Injected, need I say more?
71 Road Runner
04 Dodge Ram 2500 4x4 CTD
