02 Grand Caravan check engine light #946739
03/08/11 11:42 PM
03/08/11 11:42 PM
KS
68SportSatvert Offline OP
KS
The check engine light in my 02 Grand Caravan, 3.8, is on and I've done everything to figure out what is causing it. It's been on for a long time, maybe a year, but I don't really see any change in performance other than a bit of a rough idle but I can barely tell. Had the code pulled and was told it is a "generic" code and is caused by the gas cap. Replaced it twice. Had one of the O2 sensors replaced. Had an issue like this once before and some of you helped me out and got it fixed. I drive it everyday and still get close to 20 mpg around town. Thoughts? Thanks!
Re: 02 Grand Caravan check engine light [Re: 68SportSatvert] #946740
03/08/11 11:48 PM
03/08/11 11:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
What typically is thought of as a fuel cap code is actually a code to indicate a leak in the evap system.... The gas cap is part of that but so is many feet of vacuum hose, the fuel tank, a vapor storage tank... It won't effect drivability but if you have emissions testing it won't pass with a light on....
Re: 02 Grand Caravan check engine light [Re: 1_WILD_RT] #946741
03/09/11 12:14 AM
03/09/11 12:14 AM
KS
KS
RT,
Thanks!!! I was afraid it would be one of those lines... Any idea where to start? Any help will be appreciated.
Re: 02 Grand Caravan check engine light [Re: 68SportSatvert] #946742
03/09/11 12:16 AM
03/09/11 12:16 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
gas tank vent valve
MOPAR OR NO CAR
Re: 02 Grand Caravan check engine light [Re: 68SportSatvert] #946743
03/09/11 12:19 AM
03/09/11 12:19 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The way it's typically handled it to use a smoke generator to force smoke into the gas tank & pressurize the system... it will leak from the problem area.... A guy with Dodge dealer experience may know of a common problem area like a fitting that cracks.. Might try a google search for the failure code & your vehicle yr/make/model..
Re: 02 Grand Caravan check engine light [Re: 1_WILD_RT] #946744
03/09/11 12:36 AM
03/09/11 12:36 AM
hemigod426 Offline
hemigod426  Offline
you also need quality scanner to command closed tank vent valve and purge valve,then start the smoke. 2001 and newer cars are nuts they can pick up a .025 pin rot hole in the filler tube. first thing i do to those is vent valve next is filler tube for tank, never had a line go on those there all hard molded plastic, the jeep still use rubber they go. or if you get water in vapor canister then it freezes it will crank inside...
MOPAR OR NO CAR
Re: 02 Grand Caravan check engine light [Re: 1_WILD_RT] #946745
03/09/11 12:41 AM
03/09/11 12:41 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
My '01 Chrysler Town & Country has the same problem (also 3.8). The light was on so long it burnt out....so I guess the problem's fixed! The light came on at about 80,000 miles and I've got close to 180,000 on it now. Still running great.
Re: 02 Grand Caravan check engine light [Re: hemigod426] #946746
03/09/11 03:01 AM
03/09/11 03:01 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Sounds like you still work on this stuff regularly... I haven't wrenched on cars for a living since the late 90's, I dealt with a few evap faults but it's been years & I've tried to block that stuff from my memory..
Re: 02 Grand Caravan check engine light [Re: 1_WILD_RT] #946747
03/09/11 11:47 PM
03/09/11 11:47 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
my 97 caravan had the same evap code, I checked all the lines and hoses,changed the gas cap, I don't have a smoke machine,i did not see any cracks in the lines and hoses...had this problem for the past year or so...seems to come up during the colder weather...it just happens that my 3.3 fuel rail leaked and I had to replace it..with that in mind, the pcv hose runs in the back valve cover and it was hard as a rock and brittle to the touch...I changed the hose out with a new pcv and guess what?...all GONE...this was my fix....
Re: 02 Grand Caravan check engine light [Re: AARCONV] #946748
03/10/11 12:00 AM
03/10/11 12:00 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Some of the caravans have the evap canisiter under the van in front of the fuel tank, the rubber hoses that connect the lines will have cracks in the, if so replace the rubber hoses with fuel hose only and reset the P.C.M and recheck. If is not there let me know and I'll check location of the evap canister and let you know...Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: 02 Grand Caravan check engine light [Re: Wicked49670dart] #946749
03/10/11 08:53 AM
03/10/11 08:53 AM
KS
KS
Thanks guys! Matt, I know where the evap canister is and will start there. I will also check the PCV valve and line as well as any other line I can find. More to come...
Re: 02 Grand Caravan check engine light [Re: Wicked49670dart] #946750
03/10/11 02:51 PM
03/10/11 02:51 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Also check the evap test port (has a green cap on it the size of a valve stem cap) located between the air cleaner housing and the engine. The hoses that are on either side of the test port crack. Also take a good look at the fuel filler tubing from the gas cap to the fuel tank. They like to rust out especialy up around the end of the tube by the gas cap.
By the way the evap canister is located on the left frame rail behind the front subframe and in front of the fuel tank.
Re: 02 Grand Caravan check engine light [Re: Todd] #946751
03/10/11 10:53 PM
03/10/11 10:53 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
It will probably be the LDP the leak detection pump. Pretty common on the caravan.
Re: 02 Grand Caravan check engine light [Re: wheelsup68dart] #946752
03/11/11 12:57 AM
03/11/11 12:57 AM
KS
KS
Thanks for the additional info! I can't do anything until the weekend so I'll let you know how it goes. Where is the leak detection pump??
Re: 02 Grand Caravan check engine light [Re: 68SportSatvert] #946753
03/11/11 05:20 AM
03/11/11 05:20 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Right underneath the steering rack on the left side.
Re: 02 Grand Caravan check engine light [Re: Todd] #946754
03/11/11 09:19 AM
03/11/11 09:19 AM
Bolingbrook, IL
HemiRunner Offline
super street
HemiRunner  Offline
super street
Bolingbrook, IL
Common mini van evap problems are the LDP (leak detection pump) or lines. Evap canister site right under the steering rack on the cradle. Rack leaks fluid on top of it. Connections to canister are rubber & crack. Solenoid mounted to right front core support & has two lines coming off & need to be checked for cracks. One goes down towards the canister & other to the intake. Smoke & scanner are the best ways to find evap problems, but you checking all lines & connections are a good start. Also look at gas cap seal/o-ring. If dry & cracked could be the source as well.
Blown & Injected, need I say more? 71 Road Runner 04 Dodge Ram 2500 4x4 CTD
Re: 02 Grand Caravan check engine light [Re: HemiRunner] #946755
03/11/11 11:44 PM
03/11/11 11:44 PM
KS
KS
Thanks HemiRunner! Now I have a map of what to check. Looks like I have a mission for tomorrow.
Re: 02 Grand Caravan check engine light [Re: 68SportSatvert] #946756
03/12/11 12:01 AM
03/12/11 12:01 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
There is a hard plastic line running from the front to filler tube(you can see most of it under the van). If you follow it forward from the filler tube, you should see an elbow connection that is rubber. If it is the original elbow piece it will most likely have many cracks in it.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 02 Grand Caravan check engine light [Re: Rapid340] #946757
03/13/11 12:52 AM
03/13/11 12:52 AM
Appleton, Wisconsin
rtmike Offline
rtmike  Offline
Appleton, Wisconsin
Black electrical tape over the useless light helps too.
Its not primer its perma gray.
Re: 02 Grand Caravan check engine light [Re: Todd] #946758
03/13/11 05:05 PM
03/13/11 05:05 PM
Alameda, CA
W
Wilkram Offline
Wilkram  Offline
W
Alameda, CA
have a 01 Durango, had a cracked line by the evap test port. easy fix, hard to find.
