What size is the pinion nut? #946576
03/08/11 09:24 PM
03/08/11 09:24 PM
KY
juicedcuda Offline OP
KY
I am going to replace my pinion yoke with a billet one. What size is the pinion nut and is there anything special I need to do when replacing it, just an unbolt and bolt back on deal?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: What size is the pinion nut? [Re: juicedcuda] #946577
03/08/11 09:28 PM
03/08/11 09:28 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
what rear end are we talking?
Re: What size is the pinion nut? [Re: DJVCuda] #946578
03/08/11 09:29 PM
03/08/11 09:29 PM
KY
KY
Sorry, dana 60.
Re: What size is the pinion nut? [Re: juicedcuda] #946579
03/08/11 10:12 PM
03/08/11 10:12 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
1 5/16"
Re: What size is the pinion nut? [Re: Forest] #946580
03/08/11 11:46 PM
03/08/11 11:46 PM
1 5/16"
Re: What size is the pinion nut? [Re: Forest] #946581
03/08/11 11:47 PM
03/08/11 11:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
And it requires a thinner wall socket than usual, needs 200-250 ft lbs, and affects the pinion depth. Check your pattern after you're done.
Re: What size is the pinion nut? [Re: topside] #946582
03/09/11 12:15 AM
03/09/11 12:15 AM
KY
KY
So it needs to be torqued to 200-250 ft lbs? And how do I go about checking the pattern?
Re: What size is the pinion nut? [Re: juicedcuda] #946583
03/09/11 12:27 AM
03/09/11 12:27 AM
Washington
SuperStock68Dart Offline
Washington
Just torque it and be done with it! If the rear pinion bearing was seated before there is no way the depth can change!!
Re: What size is the pinion nut? [Re: juicedcuda] #946584
03/09/11 12:37 AM
03/09/11 12:37 AM
If you don't have a set of instructions or service manual on how to set a set of gears up you need to get one, maybe have someone who is proeffecteint on setting them up help you for the first time There are four different things that need setting up on a Dana 60 rear end, pinion gear depth, pinion bearing preload, carrier bearing preload and backlash
If you have a early Dana 60, not a Strange Engr., unit all of those setting are done with bearing shims
Re: What size is the pinion nut? [Re: juicedcuda] #946585
03/09/11 12:43 AM
03/09/11 12:43 AM
Washington
Washington
Aren't you just changing the yoke? The rear is together and has been run....correct? If so just install the thing and torque it!!
Re: What size is the pinion nut? [Re: SuperStock68Dart] #946586
03/09/11 08:15 AM
03/09/11 08:15 AM
KY
KY
Correct, this rearend has about 40 passes on it, I am just upgrading to a billet yoke while switching to a Powerglide. Never any problems from the rearend.
Re: What size is the pinion nut? [Re: juicedcuda] #946587
03/09/11 10:32 AM
03/09/11 10:32 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Some are getting the Dana and 489 mixed up. On the Dana you'll not change anything by changing the yoke. On a 489 its possible to collapse the crush sleeve when changing the yoke so it has to be re-checked. Have fun.
