Please critique my 383 build #945820
03/07/11 10:52 PM
03/07/11 10:52 PM
USA
JoesMopar Offline OP
USA
Ok, I have decided on everything I am doing to my 383 that will go in my '70 Coronet.
KB 400's
440source heads (80cc closed chamber)
XE 274 cam/lifter kit
Performer RPM intake
MP ignition kit
1 3/4" headers
750 carb
How does this combo sound to you guys? Just want a nice streetable engine. Any idea if I will have DECENT compression and quench (stock deck height).
Re: Please critique my 383 build [Re: JoesMopar] #945821
03/07/11 10:56 PM
03/07/11 10:56 PM
Central NC
gch Offline
gch  Offline
Central NC
Sounds like a well matched setup.A quality 11" converter and some 3.55's will make it happy.Run 1 3/4 long tube headers and 2.5 mandrel exhaust for best results.For more cruising/less racing one step smaller on the cam and 3.23's will be a smooth but still quick ride.
Re: Please critique my 383 build [Re: gch] #945822
03/07/11 11:02 PM
03/07/11 11:02 PM
Baltimore, MD
moparbob71 Offline
moparbob71  Offline
Baltimore, MD
750 carb my 383 ran a whole lot better with a 650. Same general build. You might have to jet it down.The rest sounds great
Re: Please critique my 383 build [Re: moparbob71] #945823
03/07/11 11:19 PM
03/07/11 11:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats close the the 383 we ran in my sons Dart. It had stock pistons with 906 heads I milled and bowl blended and got 9.5 comp. I used the RPM intake with a 750 DP. But I used the MP .484 cam and ran 3.91's with a Turbo Action 10" tight 3000 converter. I had the cam on a 104 centerline and it ran great. The Dart weighed 3550 with my sons 190 in the car. On G/60-15 McCreary's it ran a best of 12.31 @ 110. It really was a nice running combo. Yours sounds like it will run good. This is my sons Dart and it has the 400 in it in this pic but we used the 383 in it first for years. Ron
Re: Please critique my 383 build [Re: moparbob71] #945824
03/07/11 11:21 PM
03/07/11 11:21 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Sounds good to me! How far down in the bore are the pistons going to be? You may want to go through those heads before you slap them on your engine. I've read some scaring things about those heads on this web site! Also go with the valve springs that your cam calls for. Have you fired it up yet? If not make sure you use oil with plenty of zinc/phosphates and break-in oil. I too have a 69 383 that I had rebuilt a couple years ago with those same pistons. Also make sure you gap the top rings the way Keith Black recommends them.
Re: Please critique my 383 build [Re: JoesMopar] #945825
03/07/11 11:46 PM
03/07/11 11:46 PM
sounds pretty good but I'd maybe go a tad smaller on the cam/carb & you could find what 383 deck heights come in at which'll b diff I'm sure from the listed height & with the piston CH/rod C to C & 1/2 the stroke & the head gasket figure your CR as close as you can on the KB calculator. Are the KB 400's a quench pad piston and b aware that the quench pad height is not included in the CH dimention & iirc the ones for my 451 (dont remem the # right off hand) the pad is an addt'l ~.060". You'll want the SCR up higher & I'd consider having someone good, port em as you've went this far otherwise (reportedly) you may b dissapointed (if no porting) & will b leaving ALOT on the table. Sure I cant persuade you to build a 451 (400 B block/440 crank) . There'd b less down time as you'd b driving the 383 till the 451 is ready to drop in & the outside dimentions would b the same so all the externals would fit right up & the torque diff would b night and day
Re: Please critique my 383 build [Re: JoesMopar] #945826
03/08/11 09:03 AM
03/08/11 09:03 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Almost identical build as mine. Slightly smaller cam, Comps 275DEH (235/482). Was able to use the stock head gear. No real quench at .063 with Felpro's 8519. Stock deck height. Runs really well, I'm happy. I'm at 9.9:1 compression.
Re: Please critique my 383 build [Re: JoesMopar] #945827
03/08/11 09:07 AM
03/08/11 09:07 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what gear and converter? what 750 carb? I don't know why a 750 would be to big. As mentioned that cam will like a little stall and gear.
Coming soon!!!!
Re: Please critique my 383 build [Re: moparbob71] #945828
03/08/11 10:33 AM
03/08/11 10:33 AM
IL
71383beep Offline
71383beep  Offline
IL
Running a 650 Mighty Demon on mine and really like it. top end is probably a little down, but bottom end responsiveness is very snappy.
I also am not a huge fan of the heads either, but too each there own. At least they are closed chamber which will help a ton.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Please critique my 383 build [Re: JoesMopar] #945829
03/08/11 10:50 AM
03/08/11 10:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I wouldn't use the KB400 if you are going to have a pair of 80cc heads, your compression ratio is going to 10.5 and since this is a street cruiser you don't need that , building to use 89 octane is a better idea than 93 or more.
A flat top piston would be a much better choice , the Speed Pro 2315 will not require as much decking of the block to get it close to zero.
I just checked the KB site , they say 10.5 with an 80cc head , but they don't tell you that's is after you cut .024 off the block to bring it to zero. If you just skim the block to square it then your compression will be 9.8ish, which is better.
I'd pick a better cam also.
Re: Please critique my 383 build [Re: RapidRobert] #945830
03/08/11 11:01 AM
03/08/11 11:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
KB does not make a quench pad piston for the 383 , they should it would be a better choice than the dome piston ,
Re: Please critique my 383 build [Re: JoesMopar] #945831
03/08/11 01:16 PM
03/08/11 01:16 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Fuel economy = small carburetor 600 to 670
Performance = 3310 Holley 750
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Please critique my 383 build [Re: JohnRR] #945832
03/08/11 06:10 PM
03/08/11 06:10 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Suggestions???
Any chance that valve to piston clearance would be an issue for that cam considering the lack of valve pockets in the Speed Pro 2315?
Re: Please critique my 383 build [Re: rss] #945833
03/08/11 11:28 PM
03/08/11 11:28 PM
USA
USA
Thanks for all the input.
I found a compression calculator and I'm coming up with just a tad over 10:1 using the positive 6cc from the KB 400s, a .039" head gasket, 80cc heads, the piston .020" in the bore, a 4.28 bore and a 3.38 stroke.
Re: Please critique my 383 build [Re: JoesMopar] #945834
03/09/11 01:20 AM
03/09/11 01:20 AM
Might want to mock it up & see what the deck height actually ends up being as you can then mill the piston deck/valve reliefs for VP clearance/less CR if need b then dissassemble & have it balanced and depending on your octane you may want to adj the CR but w alum heads you can get by w (& prefer) higher & I like to b able to max the adv curve WO having to compromise it cause the DCR is too high for the octane. Good Luck & holler what CR it ends up being and how it ends up running for you
Re: Please critique my 383 build [Re: JoesMopar] #945835
03/09/11 05:37 AM
03/09/11 05:37 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Looks good to me.
You may want to look into the Retroteck / Professional Products Powerjection III TBI system.
750 cfm says it supports 550HP? It looks like an easy to install FI system, and comes with the fuel system for $1650.00
http://www.retrotekspeed.com/products/powerjection-iii/powerjection-iii-system.html
http://www.summitracing.com/parts/PFS-70026/
Re: Please critique my 383 build [Re: RapidRobert] #945836
03/09/11 05:48 AM
03/09/11 05:48 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
With alum heads ...I would do more CR and then use pump-premium.
Re: Please critique my 383 build [Re: Junky] #945837
03/09/11 07:30 AM
03/09/11 07:30 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
Performance+economy=Thermoquad
Re: Please critique my 383 build [Re: Junky] #945838
03/09/11 10:38 AM
03/09/11 10:38 AM
IL
71383beep Offline
71383beep  Offline
IL
My car gets at best around 13/14 so i don't really see the huge savings of the 650 vs the 750.
