never seen a 727 like this #945111
03/07/11 01:12 AM
03/07/11 01:12 AM
Denmark, WI
mopararty Offline OP
Denmark, WI
I have never seen a 727 big block trans like this. Look at the tailstock. The access cover to the tailshaft is on the side instead of on the bottom. I don't know what it came off/out of. Any one know the story behind these? Is this thing worth rebuilding?
Re: never seen a 727 like this [Re: mopararty] #945112
03/07/11 01:44 AM
03/07/11 01:44 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had a tailshaft housing like this once. I took a worn out 727 in for rebuilding and they gave me this type back....I guess they treated transmissions like The parts houses treat alternators and starters. Rebuild a core, take in a core.
I figured that the wierd housing was for a truck or van. The idea of it being from a van is unlikely with yours, since vans had a hole drilled at the top of the bellhousing to set the ignition timing. I didn't see a hole in your trans. My trans in the Charger HAS the hole in it. No prob in a NON van app. Probably helps ventilate the converter a little.
Re: never seen a 727 like this [Re: mopararty] #945113
03/07/11 02:51 AM
03/07/11 02:51 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Its a 72 up truck tailhousing. Its worth rebuilding.
Re: never seen a 727 like this [Re: earlybee] #945114
03/07/11 08:31 AM
03/07/11 08:31 AM
scratchnfotraction Offline
just a truck tranz
the cover with the 2 screws is to get at the snap ring to remove the tail housing
may have HD parts inside like a 4 gear plantgear set up..ect
well worth rebuilding,is it a sb or bb tranz?
you can tell by the look and bolt spaceing on the bell housing
Re: never seen a 727 like this [Re: mopararty] #945115
03/07/11 06:44 PM
03/07/11 06:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The side plate housing has reportedly caused some clearance problems in certain car bodies....not an issue in trucks.
