Stainless brake lines worth it? #944215
03/06/11 03:50 PM
03/06/11 03:50 PM
southern Idaho
moparcyco Offline OP
southern Idaho
As the title implies are they worth the little bit extra they cost?I'm going to order a set this week was just wondering what you guys think.None of my original stuff was usable thats kinda why I thought stainless woul be better for longevity.any thoughts or opinions are welcome thanks guys.
Re: Stainless brake lines worth it? [Re: moparcyco] #944216
03/06/11 04:04 PM
03/06/11 04:04 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Well unless you plan on doing a lot of winter driving through the salt and gravel, I don't think you'll wear out another set of regular steel brake lines in your lifetime.
Re: Stainless brake lines worth it? [Re: moparcyco] #944217
03/06/11 04:48 PM
03/06/11 04:48 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Ahhhh,....nothing better than looking at rusty steel lines under a fresh resto after a few years,...spend the money, go stainless, do it right the first time,...just think if the factory had done stainless in the day, you wouldn't be asking this question,...
Re: Stainless brake lines worth it? [Re: moparcyco] #944218
03/06/11 05:18 PM
03/06/11 05:18 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have replaced my lines with stainless. The lines I replaced were rusted for a reason. Brake fluid will absorb water out of the air. Most people don't flush their brake lines every few years, so the stainless is good insurance. Same with all the alcohol and additives they put in gas these days.
Stainless fuel lines are a good idea, and easy to replace the 5/16" with 3/8" for better fuel flow.
Re: Stainless brake lines worth it? [Re: moparcyco] #944219
03/06/11 05:18 PM
03/06/11 05:18 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
spend the money! i've had some for 15 years and they look as good as the day i bought them. just don't expect to cut and flare your own!
Re: Stainless brake lines worth it? [Re: mikemee1331] #944220
03/06/11 05:33 PM
03/06/11 05:33 PM
southern Idaho
southern Idaho
Thanks for the replies that helps make the decision stainless it is.Thanks guys
Re: Stainless brake lines worth it? [Re: 451Mopar] #944221
03/06/11 05:35 PM
03/06/11 05:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
......with steel, it's going to rust inside, as well as outside..eventually,
I replace every steel line on my personal cars (I encourage my customers as well), not one steel line of any type left in place,...plus if you polish them out by hand, they stay that way
