Hoosier Tire Comment #943875
03/06/11 02:32 AM
03/06/11 02:32 AM
Brea, Ca
Dart Racer Offline OP
Brea, Ca
I just went to the Hoosier Stiff Sidewall's 10.5W on my Dart and OMG! What an awesome tire. On the stop the best 60' I ever had was a 1.44 and today at Phoenix Speedworld had a 1.383!!!!! I am impressed! Running them at 14 lbs and this ole Dart loves it. I left the caltracs and shocks at the same settings as with the old MT tires, so the gain was strictly from the tire.
The best 60' ever was at full throttle and that was a 1.41 so beat my absolute best on the stop.
Re: Hoosier Tire Comment [Re: Dart Racer] #943876
03/06/11 02:49 AM
03/06/11 02:49 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I run a 32-13.5w stiff sidewall on the Arrow...don't tell anyone but this is going into my 4th season on this set. May have to spring for some new ones in the future. They do work well..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Hoosier Tire Comment [Re: Dart Racer] #943877
03/06/11 02:49 AM
03/06/11 02:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Awesome ! Ron
Re: Hoosier Tire Comment [Re: 383man] #943878
03/06/11 08:55 AM
03/06/11 08:55 AM
They dont last long. 38-40 passes with a small burnout.After that the 60 foot goes away.
Re: Hoosier Tire Comment #943879
03/06/11 09:37 AM
03/06/11 09:37 AM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
I run the 31.5/13.5-15 C07 stiff sidewall
like Eric this is my 4 season
congrats on your new times
Re: Hoosier Tire Comment [Re: MOPARCHAS] #943880
03/06/11 11:26 AM
03/06/11 11:26 AM
Guess you dont race much then.
Re: Hoosier Tire Comment #943881
03/06/11 11:52 AM
03/06/11 11:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I got more than 40 passes but I can tell how many
passes are on my tires based on the 60' times...
when they are new I get a 1.20 after 20 passes its
1.21 after 40 its 1.23 on the same track but after
that it seems to stay at 1.23 or so
Re: Hoosier Tire Comment [Re: MR_P_BODY] #943882
03/06/11 11:58 AM
03/06/11 11:58 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hoosier Tire Comment [Re: hemi-itis] #943883
03/06/11 12:00 PM
03/06/11 12:00 PM
tboomer Offline
tboomer  Offline
I have had good luck with Hoosiers...What do you have on the back of your car,Al?
Re: Hoosier Tire Comment [Re: MR_P_BODY] #943884
03/06/11 12:09 PM
03/06/11 12:09 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I put on a set of Hoosier 31.5 12.5W (D-05) in an effort to get up on the tire faster. They grab like nobody's business. Going to a 2nd gear only burnout next to keep from trashing the front clutches; It really pulls my little small block down in 3rd unless rpm is way up there.
Mr P: They'll never be able to replace you as a Mod. Good job
Yeah, it's got a smallblock.
Re: Hoosier Tire Comment [Re: 340B5] #943885
03/06/11 12:29 PM
03/06/11 12:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Tried a set once and no matter what we did they just wouldn't work for us. Went back to Phoenix and got our 60 to work again. I was amazed that a tire change could go so wrong on my car.
Re: Hoosier Tire Comment #943886
03/06/11 12:35 PM
03/06/11 12:35 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Keith...I haven't raced as much as I use to the past couple of years ...but I would say still 100-150 passes a year...So on three years these tires are close to 400 passes easily...granted the car is #2300 race ready too.
Re: Hoosier Tire Comment [Re: J_BODY] #943887
03/06/11 12:43 PM
03/06/11 12:43 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
Thats is pretty good to hear. I changed to 32/14.5w for this season for better 60's and more consistancy.
Re: Hoosier Tire Comment [Re: mistress] #943888
03/06/11 12:48 PM
03/06/11 12:48 PM
IMO Hoosiers are a Walmart type slick. Soft compound which works fantastic for about 38-40 passes and then little by little 60 foots go away. I believe the sidewall breaks down 1st and then its shot.
Mickey Thompsons and Phoenix seem to last the longest. But what do I know. I only 60 foot 1.21
Re: Hoosier Tire Comment #943889
03/06/11 02:07 PM
03/06/11 02:07 PM
hemi-itis Offline
hemi-itis  Offline
Sure sounds like you got that car flyin'!!What is your home track??How 'bout a link to some pictures of your car??
Re: Hoosier Tire Comment #943890
03/06/11 02:55 PM
03/06/11 02:55 PM
Locomotion Offline
Locomotion  Offline
You know that M/T and Phoenix work better with your particular combo! Each tire is different and each car is different - weight, gearing, torque, suspension, converter, carb set-up, footbrake/trans brake, track prep, etc. People also run different rim widths and different air pressures. Low air pressure or the wrong tire for the application will kill the sidewall. With so many variables, a broad statement about a whole brand of tire doesn't hold water.
I run my 9" Hoosiers until the wear holes are all but gone. I haven't counted, but runs are well over 100. My 60's have been as good as 1.47 - but that's at 3,550 lbs with a very rule restricted 360. Faster, heavy Stockers are well into the 1.30's with 9" Hoosiers. Just providing examples I'm aware of.
Re: Hoosier Tire Comment [Re: Locomotion] #943891
03/06/11 03:11 PM
03/06/11 03:11 PM
My ride is over 3300 lbs. heavy car and I see my 60 foots going away after 38-40 passes with Hoosiersregardless.
Same car with M/T I got over 180 passes and they still 60 foot the same.I change mine out every year regardless.
1.47 60 foot is that your best or was it 1.42 and then went to 1.47 as time went on?
Re: Hoosier Tire Comment #943892
03/06/11 03:19 PM
03/06/11 03:19 PM
Locomotion Offline
Locomotion  Offline
1.47 was my best. Usually it's around 1.49 - 1.50 running in "bracket mode". I've seen it vary between tracks. It's also with only SS springs. 11.22 @ 116+ best. Sounds like you may have 1.5-2x the HP, much better suspension as well as wider tires.
Re: Hoosier Tire Comment #943893
03/06/11 03:21 PM
03/06/11 03:21 PM
hemi-itis Offline
hemi-itis  Offline
Re: Hoosier Tire Comment #943894
03/06/11 04:09 PM
03/06/11 04:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
First off congrats on the new bests. Alwasy good to run a new best on the car. We did the same yesterday, a new best with the stop bolted on the car running it all out. The stop slows the car .2-.25.
I think someone needs to attend a Div or National event and take a look in the Super Class staging lanes. I would say you will find a very large percentage of those cars running Hoosiers. We care more about 60' consistency than most racers do. FWIW I put 120+- passes a year on my junk. But what do I know I only 60' 1.15
In the end it boils down to your particualr combination. I have run Goodyear and M/T on the Cuda. They both have thier pros and cons. What tire is right for YOUR car depends on a lot of factors. I am using M/T 33x15 SS tires currently. They have a bit more roll out than I like but so far so good. Been very consistent especially on the stop. Previously I ran Goodyears for a couple of years and other than my turd of a car beating up the sidewalls they worked fine. BTW on ANY drag tire the sidewalls will go away before the tread wear dots do...
