Distributor Help
#943666
03/05/11 08:42 PM
03/05/11 08:42 PM
Posts: 1,300 Washington
19cuda73
Washington
I have 2 340 motors. One is original to the car and the other is also a motor built in late 72. It has been rebuilt and upgraded. I was getting ready to install my distributor today and pulled both of them out and noticed one has the vac advance and the other has a block off plate. Would anyone happen to know why both of these parts (same part number and build date) are of different configurations? This blockoff plate appears to have been factory installed. Not sure? Has anyone come accross this before.
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
Re: Distributor Help
[Re: 19cuda73]
#943667
03/05/11 08:44 PM
03/05/11 08:44 PM
19cuda73
Washington
A shot of the block off plate.
[Re: 19cuda73]
#943668
03/06/11 09:09 AM
03/06/11 09:09 AM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
The block off plate, though well done, isn't factory.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Kowal]
#943670
03/06/11 01:49 PM
03/06/11 01:49 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
It's not ? I haven't seen one but why would someone go thru the trouble of adding both vac pod locating holes (big block and small block ) on something home grown ?
[Re: JohnRR]
#943671
03/06/11 11:53 PM
03/06/11 11:53 PM
Posts: 4,231 State of retirement
52savoy
State of retirement
My guess is... they wanted to make sure no one hooked a hose up to it because of the modifications done to it... advance plate and or advance weight springs. That's the only reason I can of..
[Re: JohnRR]
#943672
03/07/11 06:38 PM
03/07/11 06:38 PM
Kowal
Charlotte, NC
I have seen some pretty nice block off plates still sold today. Show car maybe? High end speed shop worked over the motor "back in the day"?
[Re: 52savoy]
#943673
03/09/11 02:34 AM
03/09/11 02:34 AM
19cuda73
Washington
Took the original one apart yesterday will do the modified distributor today. Cleaning up the parts.
[Re: 19cuda73]
#943674
03/09/11 12:54 PM
03/09/11 12:54 PM
Your nylon collar will probably break when you put it back together.
Lowe's has ones that fit perfectly on the shaft for .99 made by Hillman.
[Re: 19cuda73]
#943676
03/09/11 11:37 PM
03/09/11 11:37 PM
19cuda73
Washington
Took the other original unit apart with the block off plate and found the counter weights to be stock (Like the other unit) but the plates were screwed together.
