Horsepower TV Boo Boo
#943412
03/05/11 01:58 PM
03/05/11 01:58 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Watching HP TV build a "alcohol" 383 SBC. How do they figure they have a 12.5 to 1 motor with a flat top piston and 64 cc heads???? The best I can come up with is 11.25?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Horsepower TV Boo Boo
[Re: Von]
#943413
03/05/11 02:10 PM
03/05/11 02:10 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
if compression test is around 200 that could work
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#943415
03/05/11 02:12 PM
03/05/11 02:12 PM
Von
NE Oklahoma
They claimed they have a 12.5 to 1 motor...by the calculators, no way they are close.
With the cam they "said" they are using, basically a pump gas motor
The dude stated something to the lines of "You get all of this compression (12.5) by using a flat top piston? Huh.....So I was waiting for a mid 50ish cc head, nope. He then stated a 64 cc chamber.
[Re: 1 Bad Duster]
#943416
03/05/11 02:16 PM
03/05/11 02:16 PM
Von
NE Oklahoma
It made 616 hp
Ya, I saw that. But it makes me how happy their dyno is?
[Re: hemi-itis]
#943419
03/05/11 03:02 PM
03/05/11 03:02 PM
Von
NE Oklahoma
[Re: Von]
#943420
03/05/11 04:50 PM
03/05/11 04:50 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
about right with zero deck...I know with that 64cc head and flattops its usualy 10.5,11-1...the same head with a small dome that the fuelies used were 11.5...
maybe their writer just made a mistake...no add libbing
[Re: smokinwoody]
#943421
03/05/11 05:03 PM
03/05/11 05:03 PM
Von
NE Oklahoma
[maybe their writer just made a mistake...no add libbing
Maybe. But, the "big thing" was it being an alcohol motor. I dont think of a 11.25-11.50 comp motor with aluminum heads being an "alcohol" motor?
[Re: Von]
#943422
03/05/11 05:10 PM
03/05/11 05:10 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
saw that, yea no way a flat top small chevy is 12.5:1 compression unless the head has chambers super small
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Dartcuda]
#943424
03/05/11 05:30 PM
03/05/11 05:30 PM
Von
NE Oklahoma
Didn't he say they were using a .015" head gasket ?
Yes, he did, you would hope that the piston is close to .024 in the hole or they are nuts, IMO.
Even at zero deck with a .015 gasket you are still only at 11.8
[Re: Dartcuda]
#943426
03/05/11 06:24 PM
03/05/11 06:24 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Steel shim head gasket
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
