Horsepower TV Boo Boo #943412
03/05/11 01:58 PM
03/05/11 01:58 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Watching HP TV build a "alcohol" 383 SBC. How do they figure they have a 12.5 to 1 motor with a flat top piston and 64 cc heads????
The best I can come up with is 11.25?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Horsepower TV Boo Boo [Re: Von] #943413
03/05/11 02:10 PM
03/05/11 02:10 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
if compression test is around 200 that could work
home of the
Sox and Martin Hemi Duster
Re: Horsepower TV Boo Boo [Re: HEMIFRED] #943414
03/05/11 02:12 PM
03/05/11 02:12 PM
Fredericksburg,Virginia
1 Bad Duster Offline
It made 616 hp
1973 Pro Street Duster
Re: Horsepower TV Boo Boo [Re: HEMIFRED] #943415
03/05/11 02:12 PM
03/05/11 02:12 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
They claimed they have a 12.5 to 1 motor...by the calculators, no way they are close.
With the cam they "said" they are using, basically a pump gas motor
The dude stated something to the lines of "You get all of this compression (12.5) by using a flat top piston? Huh.....So I was waiting for a mid 50ish cc head, nope. He then stated a 64 cc chamber.
Re: Horsepower TV Boo Boo [Re: 1 Bad Duster] #943416
03/05/11 02:16 PM
03/05/11 02:16 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
It made 616 hp
Ya, I saw that. But it makes me how happy their dyno is?
Re: Horsepower TV Boo Boo [Re: Von] #943417
03/05/11 02:20 PM
03/05/11 02:20 PM
Fort Worth, TX
DMax One Offline
DMax One  Offline
Fort Worth, TX
It made 616 hp
Is all that smoke coming out of the breather normal?
68 Barracuda FB "Exploded View" ...still :-( 2008 Ram 2500 CTD 2007 H.D. Softail Custom 92 Jeep Cherokee
Re: Horsepower TV Boo Boo [Re: Von] #943418
03/05/11 02:47 PM
03/05/11 02:47 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
It made 616 hp
Happy as they want,they stated the numbers,didn't show 'em
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Horsepower TV Boo Boo [Re: hemi-itis] #943419
03/05/11 03:02 PM
03/05/11 03:02 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
[quote,didn't show 'em
Actually they did show them..well at least numbers on what appear to be a dyno read out.
Re: Horsepower TV Boo Boo [Re: Von] #943420
03/05/11 04:50 PM
03/05/11 04:50 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
about right with zero deck...I know with that 64cc head and flattops its usualy 10.5,11-1...the same head with a small dome that the fuelies used were 11.5...
maybe their writer just made a mistake...no add libbing
Re: Horsepower TV Boo Boo [Re: smokinwoody] #943421
03/05/11 05:03 PM
03/05/11 05:03 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
[maybe their writer just made a mistake...no add libbing
Maybe. But, the "big thing" was it being an alcohol motor. I dont think of a 11.25-11.50 comp motor with aluminum heads being an "alcohol" motor?
Re: Horsepower TV Boo Boo [Re: Von] #943422
03/05/11 05:10 PM
03/05/11 05:10 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
saw that, yea no way a flat top small chevy is 12.5:1 compression unless the head has chambers super small
Re: Horsepower TV Boo Boo [Re: Bob_Coomer] #943423
03/05/11 05:19 PM
03/05/11 05:19 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
Didn't he say they were using a .015" head gasket ?
Re: Horsepower TV Boo Boo [Re: Dartcuda] #943424
03/05/11 05:30 PM
03/05/11 05:30 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Yes, he did, you would hope that the piston is close to .024 in the hole or they are nuts, IMO.
Even at zero deck with a .015 gasket you are still only at 11.8
Re: Horsepower TV Boo Boo [Re: Von] #943425
03/05/11 05:54 PM
03/05/11 05:54 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
closer to 10.88, 11-1
Re: Horsepower TV Boo Boo [Re: Dartcuda] #943426
03/05/11 06:24 PM
03/05/11 06:24 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
Steel shim head gasket
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Horsepower TV Boo Boo [Re: racealittle] #943427
03/05/11 08:04 PM
03/05/11 08:04 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree running a zero deck piston with 0.015" head gasket and closed chamber heads is tight. But with these assumptions, I get 12.2 CR
3.75 stroke, 4.030" bore, 383 CID
zero deck
0.015" head gasket (3cc at 4" bore)
3 cc valve reliefs (small)
64 cc head
But if the piston is 0.010" down the hole, it is only 11.9
Re: Horsepower TV Boo Boo [Re: 440Jim] #943428
03/06/11 01:32 AM
03/06/11 01:32 AM
Indy
cjfordman Offline
cjfordman  Offline
Indy
From what I've heard its a wonder Joe didn't drink most of the alcohol before the dyno runs
Re: Horsepower TV Boo Boo [Re: cjfordman] #943429
03/06/11 10:15 AM
03/06/11 10:15 AM
Andrews,In. U.S.of A.
67_Satellite Offline
The power always comes from the magic "extra 2 degrees of timing"they add for the final pull.
