Header Wrap #943402
03/05/11 01:27 PM
03/05/11 01:27 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
anybody have a favorite wrap dei etc...pros and cons of what you have used...any pics would be nice too id like to see how you wrapped your headers...having a heat soak prob and need to wrap the entire header or just the section near the starter. thanks guys!
Re: Header Wrap [Re: WICKD6PK] #943403
03/05/11 03:08 PM
03/05/11 03:08 PM
michigan
black64 Offline
black64  Offline
michigan
I wrapped mine to protect the starter on my 392 hemi with block huggers to protect the starter where the exhaust pipe runs just below the starter.
Re: Header Wrap [Re: black64] #943404
03/05/11 07:32 PM
03/05/11 07:32 PM
S E Michigan
E
ekim Offline
ekim  Offline
E
S E Michigan
I wrapped a set of headers and they retained moisture and rusted out in 2 years! And they were thick metal and expensive !!!!
Re: Header Wrap [Re: WICKD6PK] #943405
03/05/11 10:45 PM
03/05/11 10:45 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Get your wallet. Open it real wide and get TTI ceramic thermals. Nice and cool
Re: Header Wrap [Re: DennisH ] #943406
03/06/11 01:41 AM
03/06/11 01:41 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Why not just get a wrap for the starter? I've done that on 2 cars and it works fine.
Re: Header Wrap [Re: topside] #943407
03/06/11 09:18 PM
03/06/11 09:18 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
well im runnin the dougs ceramic coated headers and ive tried wrappin the starter---still didnt work so thats why i thought id try wrapin the headder
Re: Header Wrap [Re: WICKD6PK] #943408
03/06/11 10:14 PM
03/06/11 10:14 PM
Could the starter itself b the prob? Just thinking out loud
Re: Header Wrap [Re: ekim] #943409
03/06/11 10:49 PM
03/06/11 10:49 PM
WI
RestoRick Offline
RestoRick  Offline
WI
I had to built a set of headers to replace the ones I custom made for my street rod. Wrapping them was a big mistake. The excessive heat retained by the wrap messes with the metallurgy and makes them brittle. You could tap mine with a hammer and they'd shatter like glass!
It only took a couple summers of driving for them to go bad.
I went to a mini starter and a heat shield... no more problems.
Rick
Re: Header Wrap [Re: RapidRobert] #943410
03/06/11 10:53 PM
03/06/11 10:53 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
It's a robbmc starter ive sent it to them they said it was ok..alltho they only put it in a conv oven I know header heat gets way hotter than that so I dunnoI've ckd everything cables u name it...batt has 1100cca...heat soak is what I'm thinking
Re: Header Wrap [Re: WICKD6PK] #943411
03/06/11 11:26 PM
03/06/11 11:26 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i'd skip the wrap,doug's say you need to use a mini starter IIRC
