318/727 converter. Factory high stall or not? #942520
03/04/11 01:14 PM
03/04/11 01:14 PM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
A friend of mine gave me a converter out of his 75 Coronet. It was a 318/727 car with factory 2.45 gears. Would the converter be a factory high stall by any chance, especially with the crap gears his car came with? There are no markings or anything on it
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 318/727 converter. Factory high stall or not? [Re: 69L78Nova] #942521
03/04/11 02:30 PM
03/04/11 02:30 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
doubt it. if it were a slanty, quite possibly.
2017 Grand Cherokee Overland
Re: 318/727 converter. Factory high stall or not? [Re: patrick] #942522
03/04/11 03:11 PM
03/04/11 03:11 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
That's unfortunate. I was hoping to use it in my Fury.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: 318/727 converter. Factory high stall or not? [Re: 69L78Nova] #942523
03/04/11 04:22 PM
03/04/11 04:22 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Some of the earlier factory manuals (1969, 1971) I have list many 318's with higher stall speeds (2400-2500 range, going from memory). I would look into it, you might be pleasantly surprised.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 318/727 converter. Factory high stall or not? [Re: 69L78Nova] #942524
03/04/11 04:33 PM
03/04/11 04:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the converter is 11" (wide ring gear) it is the high-stall commonly referred to as the 764. These were widely used prior to '78; the /6 and 318 used the exact same converter.
Re: 318/727 converter. Factory high stall or not? [Re: 69L78Nova] #942525
03/04/11 04:42 PM
03/04/11 04:42 PM
N.J. north west
1972challenger Offline
N.J. north west
I had the same converter you have in a 68 Dart 318 powered with 3:23's. The converter didn't have much stall speed. About 2000 rpm if I was lucky. Your car is a little heavier so it may go a bit higher. I would buy a convert so you know for sure what the stall speed is.
Re: 318/727 converter. Factory high stall or not? [Re: 1972challenger] #942526
03/04/11 05:59 PM
03/04/11 05:59 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
I figure its easy enough to slide the trans back and try it. I'm looking for something around an 1800 or so. It has a converter in it now that goes about 2100 while brake torquing it, but with my 27" tires and 3.55 gears, it slips way too much. At 40 mph, its turning roughly 2100-2200rpm. Im guessing there might be something wrong with the current converter. It really doesn't leave any harder than the 1500 that was in it originally. I figure the 318 verter might be a bit more livable in the meantime until I do my A500 swap.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
