Suddenly no heater blower/turn signals. Related? UPDATE #942345
03/04/11 01:44 AM
03/04/11 01:44 AM
Medford OR
FrankenScamp Offline OP
Medford OR
This is on my dart...
I'm gonna really look into it tomorrow but till then any ideas?
Fuses are fine.... Didn't know if these two items are typically tied together electrically.
Thanks as always....
Re: Suddenly no heater blower/turn signals. Related? [Re: FrankenScamp] #942346
03/04/11 10:35 AM
03/04/11 10:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Blower and TS are different circuits.Check that the blower has power to it.Do the TS light or just not flash?Might be the flasher.Rocky
Chrysler Firepower
Re: Suddenly no heater blower/turn signals. Related? [Re: FrankenScamp] #942347
03/04/11 11:03 AM
03/04/11 11:03 AM
Andrewh Offline
Andrewh  Offline
anything else not working?
technically they all tie into the ignition too.
I had that happen, but didn't kill the car because of how I have the electrical wired, I lost all accessories. Anything that required the key on to get power. Which both of those are.
Re: Suddenly no heater blower/turn signals. Related? [Re: therocks] #942348
03/04/11 11:22 AM
03/04/11 11:22 AM
Medford OR
Medford OR
Not lights at all. I'll check for juice at the blower motor first and go from there.
I'm thinkin this is all just coincidence but wanted to ask to see if I was overlooking something. Thanks for the replies guys, I'll post my findings when I tear into it.
Re: Suddenly no heater blower/turn signals. Related? [Re: FrankenScamp] #942349
03/04/11 12:54 PM
03/04/11 12:54 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Separate circuits, but fed by the ignition switch.
Wiggle the snot out of the key cylinder in the ignition switch,or look for a burnt wire from the switch.
Re: Suddenly no heater blower/turn signals. Related? [Re: superwrench] #942350
03/04/11 01:06 PM
03/04/11 01:06 PM
Medford OR
Medford OR
Will do! Thanks
Re: Suddenly no heater blower/turn signals. Related? [Re: FrankenScamp] #942351
03/04/11 02:01 PM
03/04/11 02:01 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Wiggle or unplug & reconnect the bulk head harnesses at the firwall. I had stuff like this happen before & this was the cause. You may have to clean connectors too.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Suddenly no heater blower/turn signals. Related? [Re: 6PKRTSE] #942352
03/04/11 02:32 PM
03/04/11 02:32 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Disconnect the battery and reconnect it. Your car needs to be rebooted
Re: Suddenly no heater blower/turn signals. Related? [Re: scatpacktom] #942353
03/04/11 03:11 PM
03/04/11 03:11 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The flasher is easy to check also.One side should have power with key on.Rocky
Chrysler Firepower
Re: Suddenly no heater blower/turn signals. Related? [Re: 6PKRTSE] #942354
03/04/11 05:38 PM
03/04/11 05:38 PM
Indiana
P
Pentastar440 Offline
P
Indiana
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Suddenly no heater blower/turn signals. Related? [Re: therocks] #942355
03/04/11 07:31 PM
03/04/11 07:31 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Shouldn't both sides have power with the key on ? Its only when there's a load on the circuit that the bi-metal heats up and opens the circuit hence a flashing sequence .
Re: Suddenly no heater blower/turn signals. Related? [Re: mopar_man] #942356
03/04/11 07:34 PM
03/04/11 07:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes there should be power on both sides. It's a normally closed switch.
Re: Suddenly no heater blower/turn signals. Related? [Re: stumpy] #942357
03/04/11 07:53 PM
03/04/11 07:53 PM
florida
74fldart Offline
74fldart  Offline
florida
the same thing happened to me about a month ago on my 74 dart. look under the dash above the steering column and see if the main connector to the ignition switch has come loose.
Re: Suddenly no heater blower/turn signals. Related? [Re: 74fldart] #942358
03/05/11 06:21 AM
03/05/11 06:21 AM
Medford OR
Medford OR
After all the wigglin of wires I did today and no leads yet makes me think about the ignition switch someone mentioned. I dug around in the column this mornin but nothing was obvious. No burn marks.
The turn signal cam/switch has no juice but the hazard switch still works, as do the lights
This is currently serving as my DD so I couldnt tear into it too bad this morning but come Monday I can totally disable it with confidence
Thanks for all the help fellas, it means a lot!
Re: Suddenly no heater blower/turn signals. Related? [Re: FrankenScamp] #942359
03/05/11 09:57 AM
03/05/11 09:57 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The TS flasher and 4 way are 2 seperate ones.If the ts flasher is bad the swiych wont have power even though the 4 ways work.Rocky
Chrysler Firepower
Re: Suddenly no heater blower/turn signals. Related? UPDATE [Re: FrankenScamp] #942360
03/14/11 11:07 AM
03/14/11 11:07 AM
Medford OR
Medford OR
Something in my fuse block went and killed the juice to my heater motor....so that's kinda fixed.
But the turn signals are still an issue. I traced the black wire from the flasher relay thru the fire wall, ohm'd it out so I know it's not in the bulkhead connection. It hooks to the neutral safety/reverse light switch. I have no reverse lights along w/no turn signals.
These wires also connect to the starter relay. I have no juice at this terminal with the key on, is this normal? Does the car need to be running to have juice there?
Hope this all makes sense, I'm just wondering if my starter relay is bad. Thanks!
Re: Suddenly no heater blower/turn signals. Related? UPDATE [Re: FrankenScamp] #942361
03/14/11 11:13 AM
03/14/11 11:13 AM
Medford OR
Medford OR
Also I have confirmed the ignition switch is working properly. I'm getting juice to the hazard half of the switch in the column but not juice present at the turn signal cam. The flasher relay is fine, I have no juice to either wire for the relay.
Re: Suddenly no heater blower/turn signals. Related? UPDATE [Re: FrankenScamp] #942362
03/14/11 01:05 PM
03/14/11 01:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
As said before you have two flashers one for turn and one for emergencies. Turn signals have nothing to do with neutral switch or back up lights. Completely different circuits. The wire from the neutral switch to the starter relay is a ground for the starter relay then the shifter is in park or neutral.The turn signals get their power from the ignition switch not the starter relay.
Re: Suddenly no heater blower/turn signals. Related? UPDATE [Re: FrankenScamp] #942363
03/14/11 01:26 PM
03/14/11 01:26 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Sometimes the harness that feeds through the steering column gets freyed and shorts out. I would ohm both ends of the harness starting with the red wire.
just my
If that doesn't work do what SCATPACTOM says
"Disconnect the battery and reconnect it. Your car needs to be rebooted"
..or checked for a "virus"
