Gas Tank Replacement....Any tips? #94220
07/25/08 06:42 AM
07/25/08 06:42 AM
Marion,N.C.
67chargerRandy Offline OP
Marion,N.C.
I have a new tank and all the parts to put in my 67 Charger, Is there any tips or tricks I should know before I start. This will be the first tank I have replaced. Thanks for the help.
Re: Gas Tank Replacement....Any tips? [Re: 67chargerRandy] #94221
07/25/08 07:06 AM
07/25/08 07:06 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Drain it first. Take off the little rubber vent elbow and the feed line. The J-bolt is on the passenger side. Lower it slowly until you can ease the filler tube out. Then just bring it on down. It's not very heavy. Take your time and look things over. You'll be fine.
Re: Gas Tank Replacement....Any tips? [Re: bobby66] #94222
07/25/08 07:17 AM
07/25/08 07:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
wear goggles and a mask. You won't believe what's up under that thing. and YES drain it 1st.Get the car up high. you can lower it to your chest and slide out. Clean you J-Bolts up and hit them w/ WD-40 or like the night before.
Re: Gas Tank Replacement....Any tips? [Re: 67chargerRandy] #94223
07/25/08 07:33 AM
07/25/08 07:33 AM
Don't Smoke.
Re: Gas Tank Replacement....Any tips? [Re: 67chargerRandy] #94224
07/25/08 11:11 AM
07/25/08 11:11 AM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
I just did mine and its easy . Dont forget the ground strap on tube .
Re: Gas Tank Replacement....Any tips? [Re: 67R/T4speeder] #94225
07/26/08 01:13 PM
07/26/08 01:13 PM
Marion,N.C.
Marion,N.C.
Thanks for the tips, I've drove the gas about all out, It's on the "E". I guess I'll know how much is left in the tank when the gauge says empty. It is the OEM tank so it will have a lot of "stuff" on top of it, I hadn't thought about that. I'm going to change it next week if I have time.
Re: Gas Tank Replacement....Any tips? [Re: 67chargerRandy] #94226
07/26/08 01:28 PM
07/26/08 01:28 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
tranny jack is a great help..pretty straight forward job
Re: Gas Tank Replacement....Any tips? [Re: terzmo] #94227
07/26/08 05:25 PM
07/26/08 05:25 PM
I used some black tar roofing paper & cut a piece. It looked thicker than the one we had for another tank R&R job that was either NOS or from year1,cant remember too far back.
