dambest #942120
03/03/11 09:53 PM
03/03/11 09:53 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone ever use one of these?
Re: dambest [Re: mopar dave] #942121
03/03/11 09:54 PM
03/03/11 09:54 PM
Mt Morris Michigan
Mt Morris Michigan
or this?
Re: dambest [Re: mopar dave] #942122
03/03/11 10:31 PM
03/03/11 10:31 PM
Lehigh Acres, Florida
rickstershemi Offline
Pretty ????? APD for me
Rickster
Re: dambest [Re: rickstershemi] #942123
03/03/11 11:10 PM
03/03/11 11:10 PM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
I have a matched pair, setup for a tunnelram. Worked great and made power on the dyno,would NOT work on the car. They will be going back.
Replaced them with a pair of Prosystem XE Dominators and the car works as it should.
I'm not bashing Dambest, just saying that the jury is still out.I will have more info when they are reworked and sent back to me from Dambest.
They are very expensive!
Re: dambest [Re: gillman34] #942124
03/03/11 11:13 PM
03/03/11 11:13 PM
I do know they are the most expensive. I heard great things about them.
Now seeing Gillman having trouble I'm now having 2nd thoughts about them.
Re: dambest #942125
03/03/11 11:27 PM
03/03/11 11:27 PM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
I will be trying one on a single 4bbl engine soon.
If you notice his list of record holders/winners on his site, most are single applications. They obviously work for those combo's.
I will give Dambest a chance to make them right for the tunnelram before I give them a thumbs up or thumbs down.
Re: dambest [Re: gillman34] #942126
03/04/11 12:38 AM
03/04/11 12:38 AM
Mt Morris Michigan
Mt Morris Michigan
the 4150's are $1600. let us know how they work out for you.
Re: dambest [Re: mopar dave] #942127
03/04/11 01:44 PM
03/04/11 01:44 PM
Australia
drag345 Offline
drag345  Offline
Australia
there is a rip off version that is a fair bit cheaper. looks good but it is Procomp!
http://www.atracingworld.com/NEW-PROCOMP...1B5DB142B2.html
drag345
Re: dambest [Re: gillman34] #942128
03/04/11 02:28 PM
03/04/11 02:28 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Not trying to enjoy your misfortune, but I always have to laugh at this comment. Comparing dyno results to what the carb/engine sees in the car is apples to oranges. There is no acceleration (movement), so there is no fuel being pushed to the rear of the fuel chambers to affect tuning, etc. The airflow that the carb/engine sees in the car, especially with a scoop/air pan is totally different, again affecting tuning. And since the rate of (RPM) acceleration on the dyno is typically much slower than the engine sees in first and sometimes second gears, some setups like 6-packs that rely on vacuum secondaries opening can be heroes on the dyno and a boggy, lazy POS on the track/street, due to not being able to get the secondaries in fast enough.
It boils down to while the tuner carbs can fix a lot of the fundamentals in a carb and make it easier to tune with screw in air bleeds, replaceable boosters, etc., you are very lucky to just drop on any carb OOTB and have it perform flawlessly.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: dambest [Re: Evil Spirit] #942129
03/04/11 02:42 PM
03/04/11 02:42 PM
Mt Morris Michigan
Mt Morris Michigan
I seen one of those procomps sell on ebay for $300 something. The metering blocks where different.
