is there a good/bad 518? #94151
07/24/08 11:40 PM
07/24/08 11:40 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
hello, i found a rebuilt transmission from a 94 dakota with a 318 so it should have the 518 correct? and is it a good one to swap into my 69 dodge d100 with a 318? also is there a mount that i can use from the junkyard? and will the torque converter fit without mods to the engine?
thank you
Ryan
Re: is there a good/bad 518? [Re: ryanf] #94152
07/24/08 11:52 PM
07/24/08 11:52 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I rebuilt a 94 4x4 Dakota while back and it had the A500 in it.
MM
Re: is there a good/bad 518? [Re: 500ciDuster] #94153
07/25/08 12:04 AM
07/25/08 12:04 AM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
ok well can anyone tell me the difference between the two as i have no idea
thanks
Ryan
Re: is there a good/bad 518? [Re: ryanf] #94154
07/25/08 12:09 AM
07/25/08 12:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A 500 is 904 based , 518 is 727 based , the easy way to tell is to look at the pan , just like looking at a 904 or a 727 ...
Re: is there a good/bad 518? [Re: JohnRR] #94155
07/25/08 09:31 AM
07/25/08 09:31 AM
ky.
K
kenworth_goose Offline
K
ky.
The best 518 for a preformance use will be a 518 nonlockup trans. These are more common in the 3/4 ton 89-90 trucks. Or trucks with a 360.
Re: is there a good/bad 518? [Re: kenworth_goose] #94156
07/25/08 10:20 AM
07/25/08 10:20 AM
dogdays Offline
dogdays  Offline
For putting behind a 318 in a pickup I think a lockup would be fine. I am not sure about the difference between hydraulic and electronic transmission control in a retrofit, though. John, care to elucidate?
R.
Re: is there a good/bad 518? [Re: ryanf] #94157
07/25/08 03:56 PM
07/25/08 03:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A '94 Dakota with a 318 should have a lockup 518 (actually a 46RH).
Each year brought improvements in the 518 so the latest, which was '95, would be the best. The 518 converter will bolt to any 727/904 flexplate with the 10" bolt circle.
Re: is there a good/bad 518? [Re: John_Kunkel] #94158
07/25/08 07:29 PM
07/25/08 07:29 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
so where are those numbers on the transmission so i can see what it is? and other than controlling the od unit is there anything else that i need to do other than mount and driveshaft?
ryan
Re: is there a good/bad 518? [Re: ryanf] #94159
07/26/08 04:47 AM
07/26/08 04:47 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The transmission part number is stamped in the drivers side pan rail, just below the shift lever.
If the trans is lockup you will need to control both the OD and the converter; this can be done with simple toggle switches or pressure switches in the governor test port.
Re: is there a good/bad 518? [Re: John_Kunkel] #94160
07/27/08 02:43 AM
07/27/08 02:43 AM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
so whats the best way to control the od and lockup?
Re: is there a good/bad 518? [Re: ryanf] #94161
07/27/08 11:23 AM
07/27/08 11:23 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
2017 Grand Cherokee Overland
Re: is there a good/bad 518? [Re: patrick] #94162
07/27/08 06:05 PM
07/27/08 06:05 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
so this is the number i found on the transmission can anyone decode this for me?
PK52111873015746513
thanks
Ryan
Re: is there a good/bad 518? [Re: ryanf] #94163
07/27/08 07:12 PM
07/27/08 07:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There appears to be too many digit 1's in the basic part number, PK521(1)18730 should be 52118730.
52118730 is a 518 from a '92 Dakota 4 X 2 with a 318.
Re: is there a good/bad 518? [Re: John_Kunkel] #94164
07/27/08 08:36 PM
07/27/08 08:36 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
yes your right on the numbers, so i guess my last set of questions are the mount? the only write ups ive read are on cars not trucks so will i have to fab a mount or will a stock one work? from the 94 dakota? will the torque converter bolt up right to my flexplate? and what is the honest mpg gain as the website says 30-40%??
Ryan
Re: is there a good/bad 518? [Re: ryanf] #94165
07/28/08 03:15 PM
07/28/08 03:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You'll have to fab a mount, the converter will bolt to any flexplate with a 10" bolt circle.
Mileage gains? 30-40% seems unlikely.
Re: is there a good/bad 518? [Re: John_Kunkel] #94166
07/29/08 08:37 PM
07/29/08 08:37 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
allright well i am going to take a look at it on friday and pick it up. its a "new" one from chrysler with 30,000 miles on it he has the warranty and all other info. is there anything to look out for? as its allready out? i plan on doing nothing to it and swap out my 727
thanks
Ryan
Re: is there a good/bad 518? [Re: ryanf] #94167
07/29/08 09:35 PM
07/29/08 09:35 PM
ky.
K
K
ky.
You absolutely have to use one from 95 down. The 96 and up's are controlled by the computer. It's the 46RH you need, stay away from the 46RE.
Re: is there a good/bad 518? [Re: kenworth_goose] #94168
07/29/08 10:04 PM
07/29/08 10:04 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
well i should be fine on that part as the part number calls for a 92 dakota, but 95 and down uses a 3 wire plug, and up uses a 2 wire?
Re: is there a good/bad 518? [Re: ryanf] #94169
07/29/08 11:00 PM
07/29/08 11:00 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
95 and older a-500 uses 3 wire plug.
95 and older 518 uses 3 wire plug or 2 wire plug if it's non-lock up.
96 and newer use a bigger plug with something like 10 wires.
My old 94 dakota 318 definately had an a-500 as does my currant 91 318 dakota.
Re: is there a good/bad 518? [Re: HotRodDave] #94170
07/30/08 10:49 PM
07/30/08 10:49 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
here is a picture of the pan i was sent. i think i read somewhere that there are different pans for the 518 and 500 but cant find the diagram again so maybe one of you can tell me
