Best 340 cam/intake combo #940738
03/01/11 07:16 PM
03/01/11 07:16 PM
Rancho Cucamonga,Ca
3
392charger Offline OP
Rancho Cucamonga,Ca
My son wants more power and a bigger cam in his 71 340 Demon. Currently has an old hyd 268 Magnum cam (180 lbs crankng compression)and a Crosswind (Professional Products?) intake. 99% street car with 727 auto, 355 gears, Dougs headers, manual brakes, mopar performance dist, 770 street avenger holley and a mild stall wich power brakes to around 2400. I told him to install the LD340 intake we already have but he wants to put a single plane on it along with a Mopar hyd 508(?) cam/lifter kit while retaining the stock rockers and springs. I'm not sure this would be the hot set and would need new springs at least, so I am asking for your proven combos. Thanks Moparts members
Re: Best 340 cam/intake combo [Re: 392charger] #940739
03/01/11 07:30 PM
03/01/11 07:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I think he should listen to you
Re: Best 340 cam/intake combo [Re: 392charger] #940740
03/01/11 07:31 PM
03/01/11 07:31 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Yep put the MP .509 with a single plane manifold an watch it turn into a slug. Not enough converter or gear ratio for that deal. If it's got a set of stock springs on it now you'd be best to upgrade them. The combo you have looks ok for mid to high 12's and should daily drive fine. What do the track numbers look like?
Re: Best 340 cam/intake combo [Re: 392charger] #940741
03/01/11 07:34 PM
03/01/11 07:34 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
Same here for the LD340, thats a keeper
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Best 340 cam/intake combo [Re: MonGoo$e] #940742
03/01/11 08:55 PM
03/01/11 08:55 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Father knows best!!
the old Ultradyne 223/231 on 108 in at 102 would be about as big as I'd go there and that'll work with the vert and gears, the LD 340 is a good one but if the crosswind is the airgap clone you won't tell a bit of difference between them
Overcam and undergearing a short stroke motor is not a good idea, if it was a stick and 4.10's the 508 would work a good bit better but I'd step that up one notch of the ultradyne chart to the 231/239 which is my favorite hot street 340/360 cam.
WIZE
In Car:
Re: Best 340 cam/intake combo [Re: goldmember] #940743
03/01/11 08:56 PM
03/01/11 08:56 PM
Rancho Cucamonga,Ca
3
Rancho Cucamonga,Ca
He's never had it to the track but plans on doing so this summer. It used to be my car so I know it pretty well and my seat-o pants meter would guess it runs high/mid 13's. I agree that a 509 would be the wrong cam for this car. If he were to go up a notch or two what would be a good cam to go with the LD340 intake?
Re: Best 340 cam/intake combo [Re: 392charger] #940744
03/01/11 09:22 PM
03/01/11 09:22 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""a mild stall wich power brakes to around 2400.""
Have you thought about a performance converter with the cam/intake swap?
Re: Best 340 cam/intake combo [Re: 392charger] #940745
03/01/11 09:25 PM
03/01/11 09:25 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Call Tim @bullet cams and have him use H10 lobes on a 108-110 lsa. I use it on customers cars that want strong street 340-360's that pull from 2500-6500 rpm with mild valve springs(NO STOCK SPRING),120lbs seat-275-300lbs open. I've replaced a few .509 MP cams with this and the results are fantastic. The crosswind intake has worked well and I doubt the ld430 would be an improvement,but testing is the only way to be sure.
Re: Best 340 cam/intake combo [Re: 392charger] #940746
03/01/11 09:52 PM
03/01/11 09:52 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
I have one of those .508 cams with maybe 100 miles on it, if interested PM me. A mechanic at local dealer had it in his Dart and decided it was too much for a daily driver.
Re: Best 340 cam/intake combo [Re: 392charger] #940747
03/02/11 02:15 AM
03/02/11 02:15 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
without changing anything in engine a mopar 280 / 480 < old hemi grind > would be a nice upgrade for thay engine with the ld340 intake .
Re: Best 340 cam/intake combo [Re: calrobb2000] #940748
03/02/11 10:15 AM
03/02/11 10:15 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
cam, I'd used hughes #1110 springs and a lunati voodoo 60403.
intake, I'd probably go to the LD
converter, I'd go to something in the 2500RPM stall range.
2017 Grand Cherokee Overland
Re: Best 340 cam/intake combo [Re: 392charger] #940749
03/02/11 10:41 AM
03/02/11 10:41 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Before tearing into the engine, call a reputable torque converter company and see what they recommend for the combo.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Best 340 cam/intake combo [Re: patrick] #940750
03/02/11 10:42 AM
03/02/11 10:42 AM
georgia
1340busa Offline
1340busa  Offline
georgia
i have a 72 demon 340. when i bought it it had a single plane with a 750 double pumper and a mp508 with a 3000 stall and 391 gears. it ran strong but lacked any power below 4000. i put a crosswind airgap and a 670 quickfuel tech carb on it. it really helped the bottom end. i didnt notice any loss of power on top since i shift at 6600.
Re: Best 340 cam/intake combo [Re: 1340busa] #940751
03/02/11 05:31 PM
03/02/11 05:31 PM
P
Paul_Fancsali Offline
P
The 509 is good with 4.56 gears and a stick period. Get a copy of the 68 340 stick cam and with a LD340, holley dbl pumper,4.10s that car will be in the 12s
Re: Best 340 cam/intake combo [Re: Paul_Fancsali] #940752
03/02/11 06:33 PM
03/02/11 06:33 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
that LD340 is a great intake...and a good converter is worth its weight in gold.
Re: Best 340 cam/intake combo [Re: dustergirl340] #940753
03/02/11 10:44 PM
03/02/11 10:44 PM
desomod Offline
desomod  Offline
What cam would you suggest with a 6-pak, auto with 3500 stall and 3.91 rear?
Re: Best 340 cam/intake combo [Re: desomod] #940754
03/02/11 10:53 PM
03/02/11 10:53 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Comp XE 268 Hydraulic - excellent street cam...swapped out an old street hemi grind for this cam in a 3.55 stick e-body with a 6 pak, car picked up a lot of driveability and bottom end power.
Re: Best 340 cam/intake combo [Re: 392charger] #940755
03/05/11 06:52 PM
03/05/11 06:52 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
You are already on the right path! Tweak the ignition a bit more and "optimize" your present setup,
BEFORE you start making other changes. It may surprise you for the better!! The bigger '508 cam and single plane WILL need the higher stall converter and gears to increase performance BUT it will reduce the "streetability" of the combo. Depends on how fast vs how far (in cruising) he wants to go!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
