Yep put the MP .509 with a single plane manifold an watch it turn into a slug. Not enough converter or gear ratio for that deal. If it's got a set of stock springs on it now you'd be best to upgrade them. The combo you have looks ok for mid to high 12's and should daily drive fine. What do the track numbers look like?
