smallest CLR piping #940727
03/01/11 07:03 PM
03/01/11 07:03 PM
Maryland
Sick 660r Offline OP
Maryland
I have some really tight spots for my turbo piping and im looking for the smallest clr 2.5" and 3" piping I can find. So far I found 3.75" clr for 2.5" pipe and 4" clr for 3" pipe. Anyone know of something better.
Thanks.
2000 dakota 418 magnum paxton novi 2k T56
Re: smallest CLR piping [Re: Sick 660r] #940728
03/01/11 07:09 PM
03/01/11 07:09 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
stainlessworks.net had the tightest bends i could find. call them up and tell them what you need and they can usually help you out. Also, i had the best luck using U bends where I needed the tightest of radius
Re: smallest CLR piping [Re: Sick 660r] #940729
03/01/11 07:12 PM
03/01/11 07:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Normally the smallest you can get is 1.5 times the
diameter... thats the smallest radius they can pull
Re: smallest CLR piping [Re: joshking440] #940730
03/01/11 08:05 PM
03/01/11 08:05 PM
Maryland
Maryland
stainlessworks advertises a 3.6 clr for their 2.5" pipe. Can anyone actually confirm this or do you guys think ist just 3.75?
Re: smallest CLR piping [Re: Sick 660r] #940731
03/01/11 08:21 PM
03/01/11 08:21 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
If you need REALLY tight radius bends, search for "donuts". They are two piece stampings welded together in the shape of a complete circle.
Re: smallest CLR piping [Re: TRENDZ] #940732
03/01/11 08:33 PM
03/01/11 08:33 PM
Maryland
Maryland
I completely forgot about those lol
With only a 2.5 clr would it have a negative effect on flow? I will be using a 90 right off the header collector.
Re: smallest CLR piping [Re: Sick 660r] #940733
03/01/11 09:30 PM
03/01/11 09:30 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
The donuts are neat, but $120.00 each for 304 is kind of pricey.
the donut will flow the best, but you could angle/pie cut the larger radius tube to tighten the radius.
Re: smallest CLR piping [Re: ToddP] #940734
03/01/11 10:03 PM
03/01/11 10:03 PM
Maryland
Maryland
This place has 2.5" SS for $72
http://www.covell.biz/donuts.htm
Re: smallest CLR piping [Re: Sick 660r] #940735
03/01/11 10:13 PM
03/01/11 10:13 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
That seems to be a very good price. I wonder how long it takes to special order them?
Thanks for the link.
I was looking at the pro-werks donuts.
Re: smallest CLR piping [Re: ToddP] #940736
03/01/11 10:22 PM
03/01/11 10:22 PM
Maryland
Maryland
I'll find out tomorrow when I order it. I was looking at chassis shop and they wanted $140 but theirs is 14 gauge.
Re: smallest CLR piping [Re: Sick 660r] #940737
03/02/11 05:54 PM
03/02/11 05:54 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i have seen a swedish supliers 3" 90degre bends bent on a 3" radius,crazy tight and 2 3/4" radius in 2½" tubing
hate to link a company that makes stuff that competes with what im doing everyday but well i cant compete with this anyway
http://www.ferrita.com/butik_kopia.php then click rörböj and some diferent pipes will show up..
if it can be made here i bet there is an american suplier that can make the same! i have seen one of those 3"bends and it was absolutely perfect in shape,cant realy say that about the stamped bends i have seen most of them are pretty deformed and hard to reshape to make them fit nice against a round piece of tubing,however im kind of picky about that stuff.
this is oddball that this company makes those bends since my experience is the same as Pbodys that tubesizex1.5=minimum radius its usualy the limit for what most tubing will be able to handle, just so much tension on the outside radius making it want to collapse or the inside radius to wrinkle since the material just wont compress more
