ballast resistor on 73 #940638
03/01/11 04:20 PM
03/01/11 04:20 PM
georgia
1340busa Offline OP
1340busa  Offline OP
georgia
im going with a pro comp dist and coil. i need to bypass my resistor. it is a 4 prong does the resistor have anything to do with the alt.? if not can i eliminate the wiring from the resistor forward?
Re: ballast resistor on 73 [Re: 1340busa] #940639
03/01/11 04:36 PM
03/01/11 04:36 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what type of coil, oil or epoxy (HEI style)?
Re: ballast resistor on 73 [Re: mikemee1331] #940640
03/01/11 04:41 PM
03/01/11 04:41 PM
georgia
1340busa Offline OP
1340busa  Offline OP
georgia
it is a pro comp epoxy hei style
Re: ballast resistor on 73 [Re: 1340busa] #940641
03/01/11 04:47 PM
03/01/11 04:47 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
should have asked before, what type of ECU?
Re: ballast resistor on 73 [Re: 1340busa] #940642
03/01/11 05:31 PM
03/01/11 05:31 PM
If it is a self contained dist w the ECU inside of it & a full 12V external coil yes toss the ballast & tie the run and start wires together ign1/ign2) & run them to the coil positive and to the dist whichever wire is the feed for it, red maybe. EDIT if the coil is also self contained in the dist then the same, tie run/start together & run it to the dist & there's no external coil to deal w/run a wire to
Re: ballast resistor on 73 [Re: RapidRobert] #940643
03/01/11 05:33 PM
03/01/11 05:33 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i probably should have just said that
Re: ballast resistor on 73 [Re: mikemee1331] #940644
03/01/11 05:36 PM
03/01/11 05:36 PM
You were getting ready to
Re: ballast resistor on 73 [Re: RapidRobert] #940645
03/01/11 05:36 PM
03/01/11 05:36 PM
georgia
1340busa Offline OP
1340busa  Offline OP
georgia
ok so on the resistor i am supposed to hook all 4 connections together? then run the pos. coil wire from where? can i use the orginal coil pos. wire?
Re: ballast resistor on 73 [Re: mikemee1331] #940646
03/01/11 05:36 PM
03/01/11 05:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I also ran a pro comp distributor. Pull the ballast and attach all 4 wires together.
Re: ballast resistor on 73 [Re: DaytonaTurbo] #940647
03/01/11 07:14 PM
03/01/11 07:14 PM
& run em to the dist and to the external coil positive pri terminal if using an external coil (not familiar w pro comp).
Re: ballast resistor on 73 [Re: RapidRobert] #940648
03/01/11 07:44 PM
03/01/11 07:44 PM
georgia
1340busa Offline OP
1340busa  Offline OP
georgia
i just hooked all four together and used my orginal coil wire. it fired up and ran smooth thanks! do i run my aftermarket tach to the neg side of the coil?
Re: ballast resistor on 73 [Re: 1340busa] #940649
03/01/11 09:36 PM
03/01/11 09:36 PM
the trigger wire yes
