Re: Welders: Welding Cast Iron Bellhousing
[Re: *440-6BBL*]
#940477
03/01/11 11:47 AM
03/01/11 11:47 AM
Posts: 18,157 Mass
DAYCLONA
Mass
He needs to V the weld somewhat, and drill a small 1/8" hole at the ends of the cracks to prevent them from spreading,.....I usually use a Chronatron Chronaweld Universal Cast Iron welding rod #333, and stick weld (arc) the V'd out crack, then grind and dress, blend in,...no preheating of any kind needed,.......CC Cast Iron rods are $100 lb,...cheaper rods can be purchased thru Muggy weld
Mike
[Re: JohnRR]
#940478
03/01/11 11:48 AM
03/01/11 11:48 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Sounds to me that he did not heat the parent material correctly, didnt get it hot enough before welding. Id say he just chased the crack to the end of the bellhousing.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: *440-6BBL*]
#940480
03/01/11 01:25 PM
03/01/11 01:25 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
He's using #333 Sodel rod, he wants to know if it's possible that it could be high nickel and stainless content. This guy is a pro welder for many years. thanks
What bellhousing do you have ?
