Welders: Welding Cast Iron Bellhousing #940475
03/01/11 11:40 AM
03/01/11 11:40 AM
At Your Plymouth Dealers
*440-6BBL* Offline OP
super gas
super gas
I have a 440 bell housing with 2 small cracks, welder says he is finding it cracks at the end of the weld after welding. Has anyone here have experience with these? My welder says he thinks it may not be pure cast iron, possibly an alloy mix. Any help would be great. TIA
Re: Welders: Welding Cast Iron Bellhousing [Re: *440-6BBL*] #940476
03/01/11 11:43 AM
03/01/11 11:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Did the guy welding it drill the end of the crack to stop the crack from growing ?
Re: Welders: Welding Cast Iron Bellhousing [Re: *440-6BBL*] #940477
03/01/11 11:47 AM
03/01/11 11:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
He needs to V the weld somewhat, and drill a small 1/8" hole at the ends of the cracks to prevent them from spreading,.....I usually use a Chronatron Chronaweld Universal Cast Iron welding rod #333, and stick weld (arc) the V'd out crack, then grind and dress, blend in,...no preheating of any kind needed,.......CC Cast Iron rods are $100 lb,...cheaper rods can be purchased thru Muggy weld
Mike
Re: Welders: Welding Cast Iron Bellhousing [Re: JohnRR] #940478
03/01/11 11:48 AM
03/01/11 11:48 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Sounds to me that he did not heat the parent material correctly, didnt get it hot enough before welding. Id say he just chased the crack to the end of the bellhousing.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Welders: Welding Cast Iron Bellhousing [Re: Von] #940479
03/01/11 01:06 PM
03/01/11 01:06 PM
super gas
super gas
He's using #333 Sodel rod, he wants to know if it's possible that it could be high nickel and stainless content. This guy is a pro welder for many years. thanks
Re: Welders: Welding Cast Iron Bellhousing [Re: *440-6BBL*] #940480
03/01/11 01:25 PM
03/01/11 01:25 PM
JohnRR Offline
JohnRR  Offline
What bellhousing do you have ?
Re: Welders: Welding Cast Iron Bellhousing [Re: JohnRR] #940481
03/01/11 01:29 PM
03/01/11 01:29 PM
super gas
super gas
69 440 , don't have it here so don't have the p#
Re: Welders: Welding Cast Iron Bellhousing [Re: *440-6BBL*] #940482
03/01/11 10:25 PM
03/01/11 10:25 PM
rhode island
bomber1965 Offline
bomber1965  Offline
rhode island
watch till the end when they crack an engine block...
heating cast iron
cast iron
