bleeding brakes #940242
02/28/11 10:41 PM
02/28/11 10:41 PM
ohio
geol Offline OP
geol  Offline OP
ohio
I've recently installed new brakes wheel cylinders and lines on my 72 Duster.My question is,since there is no fluid in the system should I mount the new master cylinder and fill the system before I bench bleed the new master cylinder?I am not sure if this would minimize the chance of getting air back into the master cylinder.Any thoughts?
Re: bleeding brakes [Re: geol] #940243
02/28/11 10:53 PM
02/28/11 10:53 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I kinda confused at what you said there but bench bleed the master first, then the system.
Re: bleeding brakes [Re: geol] #940244
02/28/11 10:59 PM
02/28/11 10:59 PM
Any thoughts?
I bench bleed w it in a vise then cap the ports w a pair of male inverted flare brass plugs (several $$ at your parts house in the Edelman fittings section) then install it & start on the wheels. these fittings come in VERY hand later on when isolating one half of the system from the other, well worth several bucks & if you do alot of brake work/diagnosis you WILL have a need 4 them. I've bench bled on the vehicle w the blue plastic fittings/little hoses & it can b done but it's a pain/messy
Re: bleeding brakes [Re: RapidRobert] #940245
03/01/11 12:46 AM
03/01/11 12:46 AM
Medford OR
FrankenScamp Offline
Medford OR
Bench bleed then install. Either way the entire system needs bled. Start with the rear pass then rear driver then front pass finishing with the front drivers side wheel.
That help?
Re: bleeding brakes [Re: FrankenScamp] #940246
03/01/11 01:35 AM
03/01/11 01:35 AM
hooziewhatsit Online content
hooziewhatsit  Online Content
If it were me, I'd probably bench bleed the master, open the bleeders in each corner, hook up the lines, and let it gravity bleed until you get fluid at each corner. Just don't let the master run dry. Then you can bleed as you would normally.
Re: bleeding brakes [Re: hooziewhatsit] #940247
03/01/11 01:52 AM
03/01/11 01:52 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The clean way to do it.... Get yourself a short length of 3/16 vacuum hose & an oil squirt can, make absolutely sure the oil can is clean.. I have one I use for this that never has anything but brake fluid in it.. They are easy to disassemble & clean, I suggest you do that... Fill it with brake fluid... Completely assemble your brake system then starting with the right rear loosen the bleeder screw & using the oil can push fluid back throught the brake line.. Doing it this way the first line only needs fluid pushed back to the T... Then move to the left rear & again push fluid back through the line but this time Your pushing it back till the master cylinder is maybe 1/4 full... Go to right front & repeat but this time your again wanting to raise the fluid level in the master slightly .. Then move to the left front & repeat....
Re: bleeding brakes [Re: 1_WILD_RT] #940248
03/01/11 02:50 AM
03/01/11 02:50 AM
rhode island
bomber1965 Offline
bomber1965  Offline
rhode island
Speed bleeders help also.....
Re: bleeding brakes [Re: bomber1965] #940249
03/01/11 03:37 AM
03/01/11 03:37 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Speed bleeders are great but won't help bleeding a master cylinder...
Re: bleeding brakes [Re: 1_WILD_RT] #940250
03/02/11 12:40 AM
03/02/11 12:40 AM
rhode island
bomber1965 Offline
bomber1965  Offline
rhode island
correct.....I was just throwing them in the post because they're niffty !
