Seat cover install #940168
02/28/11 09:01 PM
02/28/11 09:01 PM
S.e. lower MIch..
66droptop Offline OP
S.e. lower MIch..
Just ordered front seat covers for my car and will be doing them myself.I searched for some posts on this subject but could not find it,as I want to get as much info and pics as possable.Any help would be appreciated....Thanx....
Re: Seat cover install [Re: 66droptop] #940169
02/28/11 09:11 PM
02/28/11 09:11 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
You need hog ring pliers, and get at least two different sizes of rings--one longer, one shorter.
Do it in the warm sun if possible.
New foam is HIGHLY recommended unless yours is REALLY good (which is rare). Buckets are harder than benches, and some buckets are harder than others--it depends on the design. Plastic sheeting (a garbage bag) over the foam will help you slide the new cover over it, then you pull the plastic out. Work slowly and evenly from side to side. Stretch tight.
Others will chime in with more tips!
Re: Seat cover install [Re: Pacnorthcuda] #940170
02/28/11 09:21 PM
02/28/11 09:21 PM
S.e. lower MIch..
S.e. lower MIch..
I am getting the hog ring pliers and hogrings with the seat covers from Dante.Is there a special foam needed.I have the split bench.like the garbage bag idea.I will check the foam when I take off the old covers..
Re: Seat cover install [Re: 66droptop] #940171
02/28/11 09:29 PM
02/28/11 09:29 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
replace your foam! you can get from dante,world of diffrence in comfort and fit,you have a bench? do one of your backs at a time so you can refrence the other,take digital pics during striping,may not need but if you do you'll become super excited you took them,like said do in the sun if possible,and the trash bag idea works awesome take your time no rush
Re: Seat cover install [Re: 66droptop] #940172
02/28/11 09:30 PM
02/28/11 09:30 PM
P
Pauls69 Offline
super gas
Pauls69  Offline
super gas
P
i did mine w/out changing the foam & it came out fine. i did stuff some extra foam in some areas that needed it though. like the other poster said, better to do it on a warm, sunny day; the vinyl will be more pliable & that will make the job easier. your fingers will be sore!
